Annonces GDALOGR fr
From OSGeo Wiki
Accueil || Promotion et visibilité || Annonces de versions
Contents |
10/12/2008 - GDAL/OGR 1.6.0 Released - Sortie de GDAL/OGR 1.6.0
VO
The GDAL/OGR project team is pleased to announce the release of GDAL/OGR 1.6.0. This release represents 11 months of new feature development since the GDAL/OGR 1.5.0 release, as well as many bug fixes. The release source code is available as described at:
http://trac.osgeo.org/gdal/wiki/DownloadSource
The new release includes the following feature highlights, with detailed information on changes at:
http://trac.osgeo.org/gdal/wiki/Release/1.6.0-News
New Raster Drivers:
- BLX Magellan Topo Driver (New)
- EIR Erdas Imagine Raw Driver (New)
- Oracle GeoRaster Driver (New)
- GRIB Driver (now part of standard distribution)
- LCP (FARSITE) Driver (New)
- Terralib driver (New)
New Vector Drivers:
- Geoconcept Export Driver (New)
- INGRES RDBMS Driver (New)
- XPlane/Flightgear Driver (New)
General:
- RFC 20: Preliminary support for alternate axis orientations in SRS.
- On the fly access to data in .zip and .gz compressed files.
- RFC 22: Support for reading from, and warping with RPC (Rational Polynomial Coefficients) from various formats.
- Gaussian and Mode resampling added for overview generation.
- Added raster to vector (polygon) conversion utility.
- Added raster proximity utility.
- Added raster sieve filtering utility.
- Added -expand rgb/rgba ability to gdal_translate
- Added cutline / blend support to gdalwarp.
- Added -segmentize option to ogr2ogr to break long line segments.
- RFC 23: Preliminary support for character set transcoding (in OGR for now).
- RFC 21: OGR SQL supports type casting and field name aliasing
VF
Le projet GDAL/OGR est heureux d'annoncer la sortie de la version 1.6.0 de GDAL/OGR. Cette version représente 11 mois de travail pour l'ajout de nouvelles fonctionnalités depuis la version 1.5.0 de GDAL/OGR ainsi que plusieurs corrections de bugs. Le code source de cette version est disponible ici :
La nouvelle version inclut les fonctionnalités principales suivantes dont le détail se trouve ici : http://trac.osgeo.org/gdal/wiki/Release/1.6.0-News
Nouveaux pilotes raster :
- Pilote BLX Magellan Topo (Nouveau)
- Pilote EIR Erdas Imagine Raw (Nouveau)
- Pilote Oracle GeoRaster (Nouveau)
- Pilote GRIB (fait maintenant partie de la distribution standard)
- Pilote LCP (FARSITE) (Nouveau)
- Pilote Terralib (Nouveau)
Nouveaux pilotes vectoriels :
- Pilote du format Geoconcept Export (Nouveau)
- Pilote du format RDBMS d'INGRES (Nouveau)
- Pilote pour XPlane/Flightgear (Nouveau)
Général :
- RFC 20 : gestion basique pour l'orientation alternative des axes dans les SRS.
- accès à la volée des fichiers compressés .zip et .gz.
- RFC 22 : gestion en lecture et découpage avec des RPC (Rational Polynomial Coefficients) à partir de plusieurs formats.
- Ajout du réchantillonage Gaussian et modal pour la génération des aperçus.
- Ajout de la commande de conversion du format raster vers le format vecteur (polygone).
- Ajout de la commande de proximité raster.
- Ajout de la commande de filtre sieve des raster.
- Ajout de la possibilité -expand rgb/rgba à gdal_translate
- Ajout de la gestion cutline / blend pour gdalwarp.
- Ajout de l'option -segmentize pour ogr2ogr pour casser les segments de lignes trop long.
- RFC 23 : gestion basique de la définition de l'encodage des caractères (dans OGR seulement pour l'instant).
- RFC 21 : gestion du type cast et alias de champs dans le SQL d'OGR.
(traduction : ) yjacolin
09/02/2008 - FDO, GDAL and GRASS Graduate OSGeo Incubation - FDO, GDAL et GRASS ont passé l'Incubation OSGeo
VO
OSGeo is pleased to announce that the GRASS, GDAL and FDO projects have all graduated from the incubation process and are now a full fledged OSGeo projects.
Geographic Resources Analysis Support System (GRASS) is a Geographic Information System (GIS) used for geospatial data management and analysis, image processing, graphics/maps production, spatial modeling, and visualization.
The GDAL/OGR project provides a library and commandline tools for reading and writing geospatial raster and vector file formats. As a library it provides a single abstract data model to the calling application for all formats.
The FDO data access technology provides an API for manipulating, defining and analyzing geospatial information regardless of where it is stored. FDO uses a provider-based model for supporting a variety of geospatial data sources, where each provider typically supports a particular data format or data store.
Graduating incubation includes requirements for open community operation, a responsible project governance model, code provenance and license verification and general good project operation. Graduating incubation is the OSGeo seal of approval for a project and gives potential users of the project added confidence in the viability and safety of the project.
VF
La fondation OSGeo a le plaisir d’annoncer que les projets GRASS, GDAL et FDO sont sortis de la phase d’incubation et sont dorénavant des projets OSGeo à part entière.
GRASS (Geographic Resources Analysis Support System) est un Système d’Information Géographique (SIG) permettant la gestion et l’analyse de données géospatiales, le traitement d’images, la production de cartes, la modélisation spatiale et la visualisation.
Le projet GDAL/OGR fournit une bibliothèque et des outils accessibles en ligne de commande pour lire et écrire des données géospatiales dans des formats rasters ou vecteurs. L’application utilisant cette bibliothèque à accès à une interface logicielle abstraite unique pour tous les formats.
La technologie d’accès aux données FDO fournit une API pour manipuler, définir et analyser l’information géospatiale, quel que soit l’endroit où cette information est stockée. FDO fourni un modèle basé sur des fournisseurs afin de supporter différentes sources de données géospatiales; chaque fournisseur permet l’accès à un format de données ou de base de données spécifique.
La fin de l'incubation signifie que les éléments suivants sont présents : une communauté ouverte autour du projet, un modèle de gouvernance du projet responsable, une vérification de la provenance du code et une vérification de la licence, ainsi qu'une bonne gestion générale du projet. Passer avec succès la phase d'incubation est le sceau de l'OSGeo pour l'approbation d'un projet, et donne aux utilisateurs potentiels du projet une confiance accrue dans la viabilité et la santé du projet.
(traduction : )
