SAC:1 25 07 agenda
From OSGeo Wiki
(Redirected from SAC:1 22 07 agenda)
Jump to: navigation, search
Contents
Description of current layout and installed software
Notes from Shawn on our PEER1 system:
  • OS Version: Red Hat Enterprise Linux ES release 4 (Nahant Update 4)
  • For most elements of system i tried to stay with the default redhat locations and red hat el 4 rpms installed from peer 1's up2date repository. Reasoning, the servers are updated automatically against this repository and supported by PEER1 - reduce sysadmin load on keeping packages updated by using packages not available through PEER1 repository
Installed software using up2date
  • apache - httpd-2.0.52-28.ent.i386
  • postfix - postfix-2.2.10-1.RHEL4.2.i386
  • php - php-4.3.9-3.22PIDH.i386
  • python - python-2.3.4-14.3.i386
  • subversion - subversion-1.1.4-2.ent.i386
  • mailman - mailman-2.1.5.1-34.rhel4.5.i386
Red Hat EL 4 rpms installed manually (rpm -i)
  • MySQL-client-standard-5.0.27-0.rhel4.i386.rpm
  • MySQL-server-standard-5.0.27-0.rhel4.i386.rpm
  • MySQL-devel-standard-5.0.27-0.rhel4.i386.rpm
  • MySQL-shared-compat-5.0.27-0.rhel4.i386.rpm
  • clearsilver-0.10.1-1.2.el4.rf.i386.rpm
  • sqlite-2.8.16-1.2.el4.rf.i386.rpm
  • python-clearsilver-0.10.1-1.2.el4.rf.i386.rpm
  • python-sqlite-1.0.1-12.el4.rf.i386.rpm
Not specific to Red Hat EL 4 rpms installed manually
  • MySQL-zrm-1.1.2-1.noarch.rpm
Source Install
  • drupal-4.7.4.tar.gz
  • phpldapadmin-0.9.8.3.tar.gz
  • trac-0.10.3.tar.gz
Apache
   /var/www/html/
Subversion
   /var/www/svn/repos/
Trac
  /var/www/trac/
IP tables custom
rules must be written here or won't exist when system updated
  /etc/sysconfig/iptables-custom/
System login and maintenance procedures
-- Note: if change root password must let PEER1 know the new password for backup/restore and tickets. i would prefer no root ssh login but, PEER1 needs root access.
Subversion maintanence
  • subversion may lock if user ctl-c during checkout or checkout is interupted with an apache restart
  • Need policy on who to contact and who can run 'svnadmin recover' as
priviledged access is needed (may need to stop/start apache to drop requests to repository before recover)
Authorization and authentication for OSGeo services
Backups (offsite, live, and otherwise)
  • PEER1 is doing daily tape backup of entire system
Other backups
  • MySQL being backed up every 2 hours with MySQL-zrm
* rsync backups, to /home/back then rsynced daily to other server (osgeo.net) /etc/ (daily) /var/www/html (daily) /var/lib/mailman (every 3 hours)
         /var/lib/msql-zrm (every 3 hours)
  • subversion backups
-via svnadmin dump to /home/back/svn_dump/ (every 3 hours)
  • trac backups
-via trac-admin hotcopy to /home/back/trac_copy/ (every 3 hours)
Implementation of our virtual hosts policy and transition issues
Personal tools
