SAC:Setup CiviCRM
From OSGeo Wiki
CiviCRM is a Drupal Package for managing memberships, donations, etc. The hope is to use it to handle the membership management needs we've had going for a long time - but without having to create a whole bunch of custom content types ourselves.
Contents |
Problems
- CSS isn't perfect in Safari, especially for administration forms, using Firefox is recommended. If this affects public/non-admin pages then we'll have to fix the css somehow
Install CiviCRM
Following instructions from the CiviCRM 1.8 install for Drupal
- unzip tar ball into ~/src/civicrm
Create Folders for Drupal
Create folders with write permissions:
- /var/www/html/files/civicrm/crm_docs/
- /var/www/html/files/civicrm/templates_c/
- /var/www/html/files/civicrm/upload/
cd /var/www/html/files/ sudo mkdir civicrm sudo mkdir civicrm/crm_docs sudo mkdir civicrm/templates_c sudo mkdir civicrm/upload sudo chown -R apache.apache civicrm
Drupal Page Caching
To disable page caching for CiviCRM pages, added to /var/www/html/sites/osgeo.org/settings.php:
$conf = array( 'file_directory_path' => conf_path() .'/files', // not needed for this, but probably exists 'page_cache_fastpath' => 1, );
function page_cache_fastpath() {
if (substr($_GET['q'], 0, 7) == 'civicrm' || substr($_GET['q'], 0, 4) == 'user') {
global $conf;
$conf['cache'] = CACHE_DISABLED;
Set Up Database
I chose to keep the CiviCRM database separate from Drupal.
Install CiviCRM Code
- Verify your PHP version: 4.3.9
- Verify MySQL version: 5.0.27
- Downloaded appropriate tar ball from http://sourceforge.net/project/showfiles.php?group_id=177914
- Unzip and moved to drupal modules folder
sudo mv civicrm /var/www/html/modules/ sudo chown -R apache.apache /var/www/html/modules/civicrm
Load CiviCRM Database
cd /var/www/html/modules/civicrm/sql # Following uses _41 file even though mysql is ver 5 mysql -u civicrm_user -p civicrm_database < civicrm_41.mysql # Following loads default sample contacts, re-run above to have the db cleared after testing mysql -u civicrm_user -p civicrm_db < civicrm_generated.mysql
All ran without any trouble.
Edit CiviCRM Configuration File
cd /var/www/html/modules/civicrm cp civicrm.settings.php.sample /var/www/html/sites/osgeo.org/civicrm.settings.php Edit this file and set various settings where needed, in particular each of these lines was edited: define( 'CIVICRM_UF_VERSION' , '4.7' ); define( 'CIVICRM_UF_DSN' , 'mysql://drupaluser:PASSWORD@localhost/drupal_db?new_link=true' ); # Drupal DB define( 'CIVICRM_MYSQL_VERSION', 5.0 ); define( 'CIVICRM_DSN' , 'mysql://crmuser:PASSWORD@localhost/civicrm_db?new_link=true' ); # CiviCRM DB $civicrm_root = '/var/www/html/modules/civicrm/'; define( 'CIVICRM_TEMPLATE_COMPILEDIR', '/var/www/html/files/civicrm/templates_c/' ); define( 'CIVICRM_UF_BASEURL' , 'http://www.osgeo.org/' );
Enable CiviCRM Module and Blocks
- In Drupal admin menu, select Modules and turn on civicrm. Do the same with Blocks. This should be all we need.
- Set Access Control for CiviCRM in the normal Drupal access control admin menu. For now, admins and project managers can add/edit contacts, etc.
