SAC Meeting 2019-04
From OSGeo
Where and When =
  • in IRC on Freenode, channel: osgeo-sac
Meetings Happened
Agenda
  • OSUOSL wants to get rid of osgeo4, most drives have failed we need two new - move everything off to OSGeo7 that needs moving, reformat and install lxd. Thoughts if that is okay. markus_N said only thing he needs on adhoc is earthquake, he'll ping Jachym about pyws and martinS if anything he knows left on osgeo4
  • OSGeo7 - Have a download container on OSGeo7 and did a trial rsync of the home and osgeo folders (note bottle.download.osgeo.org is already live on it. I set on a non-standard ssh port. markusN tried to ssh into the new container and confirmed my rsync of home folders was successful and his download stuff is in good shape (permissions/date wise).
  • DONE OSGeo7 - I am going to switch the host to 2022 for ssh and leave the remainder free so if we need 22, we can use for the containers.
  • DONE 2269 OSGeo7 issue with seeing real ip - 2 ways to go - upgrade to LXD 3.11 using snap/lxd - and changed so logs are logged in nginx with the real ip. I think some work might need to be done for containers to see the real ip( but haven't checked them)
  • Setup Bacula (need some thoughts on best way to go about this since osgeo7 is not setup quite the same and for some containers seems overkill to install a bacular fd client
Talk about hardware plans
    • Regina completed install of nginx lxd container, and nextcloud.osgeo.org (which proxies thru the nginx container), set up a debian9 lxd container for ssh access but shut it down until we decide what to do with it.
    • Completed migration of projects.osgeo.osuosl.org - accessible on osgeo7 via port 50025
    • Completed migration of adhoc.osgeo.osuosl.org - accessible on osgeo7 via port 50024 - waiting for OSUOSL to repoint that domain to osgeo7
    • docker template container completed and used to build dronie server / agent
  • Discovered nginx the way currently set up can't see external ip - need to do differently than just proxying port which means we'll need a dedicated IP for nginx *UPDATE* supposedly LXD 3.0 does support nginx proxy pass ip feature, so might be fine the way it is and just need to tweak some settings
    • Can we ask OSUOSL for an extra ip
NEXT STEPS: For robe - setup container downloads.osgeo.org (will be based off of the debian9 ssh image) (for testing first with no data) and with nginx will require LDAP ssh
Budget
  • OSUOSL donation and FunToo donation are we set?
    • FunToo submitted to monthly payment plan, did treasurer figure it out?
    • OSUOSL, need to submit request to treasurer.
System Contracts
  • DONE Regina System Contract in place and she's working
  • New contract for Vicky for supporting Wordpress www.osgeo.org,
    • TODO: Draft contract and discuss
  • LDAP+SSH Keys
  • Migrating OSGeo Wiki Logins to OSGeo LDAP
Open tickets needing attention
  • 2019.foss4g.org needs oauth with github - 22228 wildintellect should close if no further feedback from requester [CLOSED]
  • https://trac.osgeo.org/osgeo/ticket/2190 (Vicky has in progress, needs feedback) [DONE still need feedback? ] - Assume DONE DONE
    • maybe we could also setup a domain like elections.osgeo.org too
    • important that only CRO has access to elections stuff
  • #2199 Upload FOSS4G PDF Waiting for feedback from Studio 17 -CLOSED because of lack of response
  • [https://trac.osgeo.org/osgeo/ticket/2195 Blog account for Astride - this should be on www.osgeo.org? Asked for clarification - CLOSED because of lack of response
  • Domain Renewals (needs ticket)
Other topics
  • are we feeling ok now with the cracked geotools account on osgeo6?
  • We need to change the passwords, and move to key only login
  • confirmed password auth is now off
  • we should clean the keys and deploy new ones
  • geotools should create new keys and supply the public key.
SAC main page
