Benchmarking 2011/Imposm
From OSGeo
Installation
Installation of imposm with all dependencies on the linux_db_bm host.
Installation steps
Install everything inside `/opt/imposm`:
cd /opt/
mkdir imposm
sudo mkdir imposm
sudo chown myusername:wms imposm
Install a recent >2.4 Python version:
cd /opt/imposm/
mkdir src
cd /opt/imposm/src
wget http://python.org/ftp/python/2.7.1/Python-2.7.1.tgz
tar xf Python-2.7.1.tgz
cd Python-2.7.1
./configure --prefix /opt/imposm
make -j2
make install
Install google-protobuf for PBF format:
cd /opt/imposm/src
wget http://protobuf.googlecode.com/files/protobuf-2.4.1.tar.bz2
tar xf protobuf-2.4.1.tar.bz2
cd protobuf-2.4.1
make -j2
make install
Install tokyocabinet for internal import cache:
cd /opt/imposm/src
sudo yum install bzip2-devel
wget http://fallabs.com/tokyocabinet/tokyocabinet-1.4.47.tar.gz
tar xf tokyocabinet-1.4.47.tar.gz
cd tokyocabinet-1.4.47
./configure --enable-off64 --prefix /opt/imposm
make -j2
make install
Install distribute/pip to install Python packages:
cd /opt/imposm/src
wget http://python-distribute.org/distribute_setup.py
../bin/python distribute_setup.py
../bin/easy_install pip
Install Imposm:
cd /opt/imposm/src
export CFLAGS=-I/opt/imposm/include
export LDFLAGS=-L/opt/imposm/lib
export PATH=/opt/imposm/bin:$PATH
pip install imposm
To install the "trunk" version change the last line from above with:
pip install https://bitbucket.org/olt/imposm/get/default.tar.gz
Importing
Creating the database:
sudo su postgres
createdb -E UTF8 osm
createlang plpgsql osm
psql -d osm -f /usr/share/pgsql/contrib/postgis-1.5/postgis.sql
psql -d osm -f /usr/share/pgsql/contrib/postgis-1.5/spatial_ref_sys.sql
Download OSM extract:
cd /opt/imposm
mkdir osm_data
cd osm_data
wget http://download.geofabrik.de/osm/north-america/us/colorado.osm.pbf
Run Imposm:
export LD_LIBRARY_PATH=/opt/imposm/lib
imposm --read colorado.osm.pbf --write --optimize --deploy-production-tables -d osm --user postgres --overwrite-cache --proj epsg:3857
The --optimize option calls VACUUM ANALYZE on all tables. Autovacuum can be disabled in PostgreSQL (and is).
And that's it:
