Canadian Geodata
From OSGeo Wiki
Back to FOSS4G2007...
Contents |
Introduction
For the FOSS4G2007 conference in Victoria, BC, Canada (September 24-27, 2007) the OSGeo Public Geospatial Data Committee would like to pull together a catalog of local data from the area around Victoria so that there would be a readily available pool of services and local datasets for Exhibitors and Presenters to use during the conference. The hope is that this will bring attention to the efforts being made by the Public Geospatial Data Committee committee. Benefits to the conference would be fast access to services (if we were to host them somewhere locally during the conference), an increased local feel, and a resource so that we could see different applications all working with the same data.
This public data will be available for use by the FOSS4G2007 Integration Showcase.
Data Custodians
Government
Federal
- The Canadian Federal Government, often in partnership with Provincial governments, makes various types of data available for free, from various sources.
Provincial
- The British Columbia Provincial Government makes some of it's data publicly available for free.
Local
- Local governments, such as the City of Victoria, or the Capital Region District may have some data available for free.
Commercial
- Various companies and organizations, whether they are Canadian or not, may have data that they would be willing to provide for free.
DataSets
Requested Datasets
If there is a particular Canadian dataset that you would like to see be available at FOSS4G2007, add your request to this section. Please include the following information:
- Dataset information:
- dataset name
- link to dataset information (e.g. metadata)
- link to dataset location (if publicly available)
- Your information:
- your name (and optionally organization), and a way to contact you
- your role in the FOSS4G2007 conference (e.g. attendee, workshop/lab instructor, sponsor, etc.)
- why you are requesting the dataset
Dataset Sources
While the authoritative source for a dataset is the dataset's custodian, for FOSS4G2007 the goal is to have copies of datasets, or partial datasets, on local servers at the conference. To accomplish that, local people will have to do the work of obtaining those copies and loading them onto the local servers.
If you can help with this by providing the conference organizers with a copy of all or part of one or more of the Requested Datasets, add your information to the section below.
- Dave Patton, Victoria, BC
- I have this data locally (i.e. it has already been downloaded), and will provide it via a USB drive
- The data is available "as is", in the format provided for the downloads. For example, this often means the data is in ZIP files, with one ZIP file per NTS tile.
- The total space for the data listed below is 66.1GB
- Toporama, version 1
- raster dataset, consisting of computer-generated topographic map images (i.e. lacking some cartographic features)
- http://toporama.cits.rncan.gc.ca/
- Note that this is the "original Toporama" dataset, not the newer Atlas of Canada Toporama (Toporama version 2).
- the images are collarless GIF images, designed to be able to be easily mosaicked
- the GIF images have corresponding world files (.wld)
- also included are small and large versions of the NTS Index 5 (British Columbia) map, with OziExplorer and JPR calibration files
- dataset covering all of British Columbia at 1:250,000 (106 images) plus British Columbia south of 56°N and some of northern British Columbia, at 1:50,000 (1,120 images) totals 512MB
- Natural Resources Canada Licence Agreement
- Geogratis: CanMatrix
- raster dataset, consisting of scans of the NTS paper topographic maps, at both 1:50,000 and 1:250,000 scales
- http://geogratis.cgdi.gc.ca/geogratis/en/collection/detail.do?id=10119
- the images are GeoTIFF, and include the map collars
- dataset covering all of British Columbia (NTS blocks 082, 083, 084, 085, 092, 093, 094, 095, 102, 103, 104, 105, 114, 115) at 1:250,000 (171 files) and 1:50,000 (2,753 files) totals 55.5GB
- Geogratis Licence Agreement For Unrestricted Use Of Digital Data
- Geogratis: Landsat 7 Level 1-G Imagery over Canada
- The L1G product is a radiometrically and systematically corrected L0R image.
- http://geogratis.cgdi.gc.ca/geogratis/en/collection/detail.do?id=2634
- Data is formatted using Hierarchical Data Format (HDF) version 4.1r2
- The Landsat7 scene for Path 27, Row 026 covers an area with a mix of terrain, and it includes the Victoria area.
- the HDF files for the Path 27 Row 026 scene, collected July 30 2000, take 229MB
- Geobase: Canadian Geopolitical Boundaries, Level 1 (CGB1)
- This data layer contains the international, inter-provincial and territorial boundaries, as well as the boundaries of Canada's exclusive economic zone.
- http://geobase.ca/geobase/en/data/cgb/index.html
- the data is available in GML and Shape files
- dataset covering all of Canada totals 22.8MB
- Geobase Unrestricted Use Licence Agreement
- Geobase: Canadian Digital Elevation Data, Level 1 (CDED1)
- The Canadian Digital Elevation Data (CDED) consists of an ordered array of ground elevations at regularly spaced intervals.
- http://www.geobase.ca/geobase/en/data/cded/index.html
- dataset covering all of British Columbia (NTS blocks 082, 083, 084, 085, 092, 093, 094, 095, 102, 103, 104, 105, 114, 115) at 1:250,000 (3 arc second) and 1:50,000 (0.75 arc second) (2,864 files) totals 6.99GB
- Geobase: Canadian Geodetic Network
- Canadian Base Network, Level 1 (CBN1)
- The CBN1 is a network of pillar monuments with forced-centring plates, positioned three-dimensionally with GPS to centimetre-level accuracy with respect to the Canadian Active Control System (CACS)
- http://www.geobase.ca/geobase/en/data/geod/index.html
- dataset of 16 GML and 16 Shape files for British Columbia totals 168KB
- Primary Vertical Bench Marks, Canada, Level 1 (PVBMC1)
- The Primary Vertical Bench Marks, Canada, Level 1 (PVBMC1) are (approximately 80000) monuments established about every 2 km along major highways and railways across Canada.
- dataset of 402 GML and 402 Shape files for British Columbia totals 4.31MB
- Federal 3-D Densification Network, Canada, Level 1 (FED3DC1)
- The Federal 3-D Densification Network, Canada, Level 1 (FED3DC1) consists of (approximately 2000) monumented stations, positioned three-dimensionally with GPS to centimetre-level accuracy with respect to the Canadian Active Control Systems (CACS). The network densifies 3-D control within the Canadian Base Network, Level 1 (CBN1).
- dataset of 71 GML and 71 Shape files for British Columbia totals 1.16MB
- Geobase: GeoBase Data Alignment Layer
- Landsat 7 Orthorectified Imagery over Canada, Level 1 (LDSAT7)
- The orthoimage data set is a complete set of cloud-free (less than 10%) orthoimages covering the Canadian landmass and created with the most accurate control data available at the time of creation.
- http://www.geobase.ca/geobase/en/data/gdal/index.html
- LDSAT7 datafiles are available in GeoTiff, PIX and BSQ.
- the GeoTiff and PIX files for the Path 27 Row 026 scene, collected July 30 2000, in both LCC and UTM projections, take 2.77GB
- Control Points for Landsat 7 Imagery, Canada, Level 1 (CPLIC1)
- A set of georeferenced points that are readily identifiable at various map scales.
- dataset of 105 GML and 105 Shape files for British Columbia totals 7.73MB
- Geobase: Canadian Geographical Names, Level 1 (CGN1)
- Subset of the Canadian Geographical Names Data Base, consisting of current officially approved geographical names.
- http://geobase.ca/geobase/en/data/cgn/index.html
- dataset of the 201 GML files and 201 Shape files for the 092 NTS block totals 4.7MB
- Geobase: National Road Network, edition 2 (NRN)
- Representation of a continuous accurate up-to-date centerline for all non-restricted used roads in Canada (5 meters or more in width, drivable and no barriers denying access).
- http://www.geobase.ca/geobase/en/data/nrn/index.html
- dataset for British Columbia, version 4.00, with GML and Shape files, in English and French, totals 127MB. As per the National Road Network Update Status page, this version of the data contains "Basic attributes", but does not contain "Street & Place Names" or "Block Face Addressing".
- Jason Birch, Nanaimo, BC
- City of Kamloops data
- 20cm Orthos
- DEM
- Cadastral base & zoning
- Possibly more vector data
- Geographic Data Download Service Disclaimer
- Justin Deoliveira, Victoria, BC
- National Topographic Data Base (NTDB)
- Vector dataset containing roads, railways, contours, hydrography, etc...
- http://geogratis.cgdi.gc.ca/geogratis/en/product/search.do?id=8147
- 1:50,000 and 1:250,000
- CanImage
- Raster dataset containing Landsat 7 orthoimages in GeoTIFF format, resampled and based on the National Topographic System (NTS) at the 1:50,000 scale
- http://geogratis.cgdi.gc.ca/geogratis/en/product/search.do?id=10757
- StatsCan Roads
- Statistics Canada Road Network File 2006 for British Columbia
- http://geodepot.statcan.ca/Diss2006/DataProducts/RNF2006_e.jsp
- Contains information such as street names, type, direction and address ranges
- Statistics Candada Road Network File Reference
