Configuration Files QGIS
From OSGeo Wiki
Jump to: navigation, search
QGIS Example XML Project File
Feel free to improve this example. It shows to layers, one with 5 classes based on an attribute.
<!DOCTYPE qgis PUBLIC 'http://mrcc.com/qgis.dtd' 'SYSTEM'>
<qgis projectname="" version="1.0.0-Kore" >
    <title></title>
    <mapcanvas>
        <units>degrees</units>
        <extent>
            <xmin>1392299.463692</xmin>
            <ymin>-273733.207354</ymin>
            <xmax>1565842.300777</xmax>
            <ymax>-147829.580449</ymax>
        </extent>
        <projections>0</projections>
        <destinationsrs>
            <spatialrefsys>
                <proj4>+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs </proj4>
                <srsid>3344</srsid>
                <srid>4326</srid>
                <epsg>4326</epsg>
                <description>WGS 84</description>
                <projectionacronym>longlat</projectionacronym>
                <ellipsoidacronym>WGS84</ellipsoidacronym>
                <geographicflag>true</geographicflag>
            </spatialrefsys>
        </destinationsrs>
    </mapcanvas>
    <legend>
        <legendlayer open="true" checked="Qt::Checked" name="popplaces" >
            <filegroup open="false" hidden="true" >
                <legendlayerfile layerid="popplaces20080823150946427" visible="1" inOverview="0" />
            </filegroup>
        </legendlayer>
        <legendlayer open="true" checked="Qt::Checked" name="roads" >
                <legendlayerfile layerid="roads20080823150655020" visible="1" inOverview="0" />
            </filegroup>
        </legendlayer>
    </legend>
    <Composer>
        <Composition paperWidth="297" paperHeight="210" />
    </Composer>
    <projectlayers layercount="2" >
        <maplayer minScale="1" maxScale="1e+08" scaleBasedVisibilityFlag="0" geometry="Point" type="vector" >
            <id>popplaces20080823150946427</id>
            <datasource>/data/popplaces.shp</datasource>
            <layername>popplaces</layername>
            <srs>
                <spatialrefsys>
                    <srsid>3344</srsid>
                    <srid>4326</srid>
                    <epsg>4326</epsg>
                    <geographicflag>false</geographicflag>
                </spatialrefsys>
            </srs>
            <transparencyLevelInt>255</transparencyLevelInt>
            <provider>ogr</provider>
            <encoding>System</encoding>
            <edittypes>
                <edittype type="0" name="AREA" />
                <edittype type="0" name="CGNDBKEY" />
                <edittype type="0" name="CONCISE" />
                <edittype type="0" name="GENERIC" />
                <edittype type="0" name="GEONAME" />
                <edittype type="0" name="NTSMAP" />
                <edittype type="0" name="PERIMETER" />
                <edittype type="0" name="POPPLACE_" />
                <edittype type="0" name="POPPLACE_I" />
                <edittype type="0" name="POP_CAT" />
                <edittype type="0" name="REGIONNAME" />
                <edittype type="0" name="SCALE_CAT" />
            </edittypes>
            <displayfield>AREA</displayfield>
            <label>0</label>
            <attributeactions/>
            <singlesymbol>
                <symbol>
                    <lowervalue></lowervalue>
                    <uppervalue></uppervalue>
                    <label></label>
                    <pointsymbol>hard:circle</pointsymbol>
                    <pointsize>2</pointsize>
                    <rotationclassificationfield>-1</rotationclassificationfield>
                    <scaleclassificationfield>-1</scaleclassificationfield>
                    <outlinecolor red="0" blue="0" green="0" />
                    <outlinestyle>SolidLine</outlinestyle>
                    <outlinewidth>0.4</outlinewidth>
                    <fillcolor red="115" blue="55" green="253" />
                    <fillpattern>SolidPattern</fillpattern>
                    <texturepath></texturepath>
                </symbol>
            </singlesymbol>
            <labelattributes>
                <label field="" text="Label" />
                <family field="" name="Lucida Grande" />
                <size field="" units="pt" value="12" />
                <bold field="" on="0" />
                <italic field="" on="0" />
                <underline field="" on="0" />
                <color field="" red="0" blue="0" green="0" />
                <x field="" />
                <y field="" />
                <offset x="0" y="0" yfield="-1" xfield="-1" units="pt" />
                <angle field="" value="0" />
                <alignment field="-1" value="center" />
                <buffercolor field="" red="255" blue="255" green="255" />
                <buffersize field="" units="pt" value="1" />
                <bufferenabled field="" on="" />
                <multilineenabled field="" on="" />
            </labelattributes>
        </maplayer>
        <maplayer minScale="1" maxScale="1e+08" scaleBasedVisibilityFlag="0" geometry="Line" type="vector" >
            <id>roads20080823150655020</id>
            <datasource>/data/roads.shp</datasource>
            <layername>roads</layername>
            <srs>
                <spatialrefsys>
                    <srsid>3344</srsid>
                    <srid>4326</srid>
                    <epsg>4326</epsg>
                </spatialrefsys>
            </srs>
            <classificationattribute>LENGTH</classificationattribute>
            <edittypes>
                <edittype type="0" name="CLASS" />
                <edittype type="0" name="FNODE_" />
                <edittype type="0" name="LENGTH" />
                <edittype type="0" name="LPOLY_" />
                <edittype type="0" name="NAME" />
                <edittype type="0" name="PROV_EN" />
                <edittype type="0" name="PROV_FR" />
                <edittype type="0" name="ROADS_" />
                <edittype type="0" name="ROADS_ID" />
                <edittype type="0" name="ROAD_" />
                <edittype type="0" name="RPOLY_" />
                <edittype type="0" name="TCH" />
                <edittype type="0" name="TNODE_" />
            </edittypes>
            <displayfield>FNODE_</displayfield>
            <label>0</label>
            <attributeactions/>
            <graduatedsymbol>
                <classificationfield>4</classificationfield>
                <symbol>
                    <lowervalue>0.207710</lowervalue>
                    <uppervalue>587.909640</uppervalue>
                    <label></label>
                    <outlinecolor red="0" blue="0" green="255" />
                    <outlinewidth>0</outlinewidth>
                    <fillcolor red="0" blue="0" green="0" />
                    <fillpattern>NoBrush</fillpattern>
                </symbol>
                <symbol>
                    <lowervalue>587.909640</lowervalue>
                    <uppervalue>1309.430080</uppervalue>
                    <label></label>
                    <outlinecolor red="0" blue="52" green="203" />
                </symbol>
                <symbol>
                    <lowervalue>1309.430080</lowervalue>
                    <uppervalue>2051.623140</uppervalue>
                    <label></label>
                    <outlinecolor red="0" blue="103" green="152" />
                </symbol>
                <symbol>
                    <lowervalue>2051.623140</lowervalue>
                    <uppervalue>3556.521010</uppervalue>
                    <label></label>
                    <outlinecolor red="0" blue="154" green="101" />
                </symbol>
                <symbol>
                    <lowervalue>3556.521010</lowervalue>
                    <uppervalue>67824.585310</uppervalue>
                    <label></label>
                    <outlinecolor red="0" blue="205" green="50" />
                </symbol>
            </graduatedsymbol>
            <labelattributes>
                <x field="" />
                <y field="" />
            </labelattributes>
        </maplayer>
    </projectlayers>
    <properties>
        <Gui>
            <SelectionColorBluePart type="int" >0</SelectionColorBluePart>
            <CanvasColorGreenPart type="int" >255</CanvasColorGreenPart>
            <CanvasColorRedPart type="int" >255</CanvasColorRedPart>
            <SelectionColorRedPart type="int" >255</SelectionColorRedPart>
            <SelectionColorGreenPart type="int" >255</SelectionColorGreenPart>
            <CanvasColorBluePart type="int" >255</CanvasColorBluePart>
        </Gui>
        <PositionPrecision>
            <DecimalPlaces type="int" >2</DecimalPlaces>
            <Automatic type="bool" >true</Automatic>
        </PositionPrecision>
    </properties>
</qgis>
Personal tools
