Google Code In 2019 Tasks
From OSGeo
Interested Mentors
Please first fill out the Google form mentioned at the top of: Google Code In 2019 Mentors
Effort for a Task
  • Each task is expected to take 3-5 hours of work to complete
  • Students have at least 3 days to complete the task
Types of Tasks
There are 5 types of Code-in Tasks in general:
Code
Tasks related to writing or refactoring code
Documentation/Training
Tasks related to creating/editing documents and helping others learn more
Outreach/Research
Tasks related to community management, outreach/marketing, or studying problems and recommending solutions
Quality Assurance
Tasks related to testing and ensuring code is of high quality
Design
Tasks related to user experience research or user interface design and interaction
Beginner Tasks
  • A student can only complete a total of 2 beginner tasks
  • Each OSGeo project should specify that a task is a beginner task by including "[BEGINNER]" at the end of the task name
Example Tasks
Project Tasks
  • see shared spreadsheet on Google Drive
Bulk Uploading Tasks
Documentation
Prep
NOTE: the python scripts for bulk uploading are written for Python2, but the instructions below should work for both Python2 & 3:
  1. git clone https://code.googlesource.com/codein/api api
  2. cd api
  3. check your Python version:
    • python -V
  4. install module "requests" through easy_install or pip:
    • easy_install requests
    • pip install requests
  5. for Python2, no more changes are needed, proceed to next sections below (export tasks, or list tasks, or upload tasts, etc)
  6. for Python3, make the following changes:
    • in list_tasks.py change print command on line# 45 to
      • print ('\t'.join([str(t['id']), t['name']]))
    • in list_tasks.py convert to an int on line# 52 to
      • next_page = int(result.group(1))
    • in csv_uploader.py change line# 64 to
      • with open(filename, 'rt') as csvfile:
    • in csv_uploader.py change print command on line# 83 to
      • print ('\t'.join(['OK', str(t['id']), t['name'], ]))
    • in csv_uploader.py change print command on line# 86 to
      • print ('\t'.join(['ERROR', , t['name'], e.response.text]))
    • in client.py change instances of "urlparse" to "urllib.parse"
Export CSV
  • export your tasks from the Google spreadsheet (assuming you created a new sheet in the shared doc Code-in Bulk Upload Spreadsheet) as CSV (File/Download as/CSV), but before that be sure to:
    • make sure that the "categories" field is comma separated INTEGERs (see the "column definitions" sheet in Code-in Bulk Upload Spreadsheet)
    • verify that your dashboard PROFILE email address is the EXACT same as what you entered in the "mentors" field in 'Code-in Bulk Upload Spreadsheet' (otherwise your uploaded tasks will have empty/missing mentor)
List Tasks through Commandline
  1. see usage of list_tasks.py
    • python list_tasks.py --help
  2. get a list of tasks at the commandline
    • python list_tasks.py --apikey [OSGeoKey]
      • should return something like:
    5126447435874304        gvSIG: Make a .....
    5172599543824384        gvSIG: Install.....
    5702068213907456        MapServer: Find and fix ....
    5723293673848832        gvSIG: Make a ....
    5761046167945216        gvSIG: Give a talk about ....
    5762611012435968        MapServer: Design a ....
    5765029615894528        MapServer: Install ....
Upload Tasks through Commandline
  1. see usage of csv_uploader.py
    • python csv_uploader.py --help
  2. upload your csv at the commandline
    • python csv_uploader.py -v --apikey [OSGeoKey] project-tasks.csv
  OK      6030299680997376        MapServer: Give a ....
  OK      5944469725642752        MapServer: Make a ....
  OK      5765029615894528        MapServer: Install ....
  OK      5702068213907456        MapServer: Find and fix ....
  OK      5770211091283968        MapServer: Fix ....
