Java 2018 Code Sprint
From OSGeo
The Java tribe has a real challenge for 2018 - updating our open source projects for the Java roadmap.
Location
Sprint scheduled for Q4 2018, proposed date:
  • October 22-26th
We are looking at setting up a distributed sprint with locations in:
  • North America - Victoria, Boundless Office, billeting options available for those travelling
  • Europe
    • Software Engineer and Computer Science School, University of Sevilla, Spain
    • Astun Office in Epsom, UK several point are gathering there
Contacts
Jody Garnett
We would like to thank our sponsors!
Silver Sponsors
Bronze Sponsors
AstunLogo.png liknk=https://uk.osgeo.org/ Atol logo.png
In-Kind Support
Participants
Please add your name and the projects you are planning to sprint and note the likehood of your attendance.
Participants
# Participant Country Organization Arrival Departure Project Work on Notes Attendance
1 María Arias de Reyna Spain GeoCat bv local local GeoNetwork Notes Confirmed
2 Jody Garnett Canada Boundless local local GeoTools Able to host guests Confirmed
3 Torben Barsballe Canada Boundless local local GT/GS Confirmed
4 Kevin Smith Canada Boundless local local GT/GWC/GS Confirmed
5 Devon Tucker Canada Boundless local local GT/GS Confirmed
6 Antonello Andrea Italy HydroloGIS TBD TBD GT/JTS, Hortonmachine Confirmed
7 Ian Turton UK Astun local local GT/GS Epsom
8 Andrea Aime Italy GeoSolutions TBD TBD GT/GWC/GS/jai-ext/imageio-ext/jaitools Home Confirmed
9 Jim Hughes US CCRi TBD TBD JTS/GT/GS/GeoMesa Confirmed
10 Landon Blake US BKF Engineers Working Remotely Working Remotely JTS/Proj4J Confirmed
11 David Vick US Boundless STL remote GT/GS Confirmed
12 Wes Richardet US Boundless STL remote GT/GS Confirmed
Discussion
Java has a roadmap?
Yes, we had a previous sprint focused on Java 8 compatibility, several features had changed breaking compatibility.
More importantly the Java roadmap has changed to a six-month release cycle:
  • six month release cycle is already well underway having started with Java 9 and Java 10.
  • Oracle is offering three year LTS releases commercially
  • AdoptOpenJDK is setting up LTS releases of OpenJDK .. backed by IBM, Microsoft and others.
  • RedHat is focusing on LTS (skipping Java 9 and Java 10) and plans to ship OpenJDK based on Java SE 11
Why is updating our open source projects for the Java roadmap a challenge?
- Java changed the service provider interface plugin system used by GeoTools, forcing the project to write its own replacement.
- The java runtime has been broken up into modules, not all of which are activated by default. We need to review what sections of the JRE we require and ensure they are turned on.
- Java introduced the module system "jigsaw" providing both a class-path and module-path for loading jars.
- When loaded on the module-path jars are prevented from using the same package. This breaks multi-jar projects like GeoTools library where gt-api defining interfaces, and gt-main providing implementations.
- Jigsaw also locks down aspects of Java reflection, affecting projects like Spring that make heavy use of reflection to "auto wire" GeoServer together. Spring 5 has been released and upgrading to this release will be a key focus.
- With these changes projects like GeoServer need to review of hundreds open source dependencies to determine what other libraries are broken, if an update is available or replacement can be found.
- The java web service framework (responsible for concepts like Servlet and Session) is being removed from Oracle oversight and has been setup as [Jakarta EE Software](https://jakarta.ee).
Recommended reading
Do you have any experience running sprints?
The GeoServer team really benefited from java 2017 code sprint and is eager to repeat the success.
GeoServer Planning
Initial planning has started:
Preflight activities:
  • dependency audit
Required updates:
  • Spring 5 - Older versions of spring are not compatible with Java 11. Upgrading to from Spring 4 to Spring 5 does involve handling some API changes.
  • HazelCast - Like Spring, HazelCast involves a lot of reflection.
Module refactor:
  • Repackage GeoServer application jars to prevent conflicts at the package level.
  • Resulting application can be used on either the CLASSPATH (Java 8) or MODULEPATH (Java 11)
GeoTools Planning
Planning and work is already well underway:
The first completed phase is to allow GeoTools to be used on the classpath:
The sprint goal is to refactor the geotools library into modules, allowing the jars to be used on either the classpath (Java 8) or the module path (Java 11).
  • Core library refactored into modules
GeoTools Java 11 modules
  • plugins used to automatic modules to dependencies on the classpath
module-path bridge to classpath
In the above illustration the gt-svg module is used as an automatic module publishing org.geotools.renderer.style.svg package. It acts as a bridge to the multi-jar project batik still on the classpath, completely masking the fact batik is used used to read and render svg files. The core module gt-renderer publishes select packages for use, while hiding others. It makes use of ServiceLocator to access the IconFactory implemented by gt-svg and never has direct use of the batik implementation.
For this to work the gt-svg jar has been refactored, moving the icon factory the new package org.geotools.style.svg. This was required as the package org.geotools.renderer.style was already published by gt-renderer.
We expect:
  • Initial focus is on the core library, refactoring to allow jars to be used on the module path as named modules
  • plugins will remain on the classpath, accessed via service locator, any conflicting packages will not be visible to client code
JTS Topology Suite Activities
Results of bonn code sprint:
JTS jars can be placed on the module-path used as an automatic module, the jars have been supplied am Automatic-Module-Name using a MANIFEST.MF entry.
For an example.application using jts-core as a module add module-info:
  module example.application {
    requires org.locationtech.jts;            // jts-core
GeoNetwork Planning
[Strategy for GeoNetwork]
Sprint Coordination
Communication
While many of us are meeting in person, we still need to communicate across teams and timezones:
Coordination
Care is required to commit everything, and hand over work from one timezone to the next.
  • Use of the Java 2018 Code Sprint Activities spreadsheet is key preventing two people working on the same problem.
  • Ask on gitter and put your name next to an activity
  • If you need to step out, or are done for the day, be sure to commit progress and let others continue!
Preflight checklist
To help get ready we have assembled a preflight checklist:
  1. JDK 11: Please install OpenJDK11
  2. Fork and clone out each project and build locally (Java 8 / master branch)
    • jaitools
    • jai-ext
    • imageio-ext
    • geotools
    • geowebcache
    • geoserver
  3. Read the proposals:
  4. Required reading:
  5. Recommended reading:
  6. Background:
Sprint Activities
The sprint is broken up into several stages, goal is to have something deliverable at the end of each stage. Care has been taken to identify activities that can be worked on in parallel.
Stage 1 Build and run in JDK 11
Done when being able to start and run GeoServer on JDK11 with release extensions loaded in
Everything in our stack builds and run without any flag added, off the classpath (it's ok to have warnings). This will allow us to get JDK 11 builds going.
  • Compile: Andrea has made considerable progress here, to mirror you need to check out and build locally all the dependencies
  • Tests: passing tests can be worked on in parallel, as long as pervious stages were able to compile without tests. This work may require updating some dependencies
  • Build: package release artifacts such as installers and javadocs
Project Compile Test Build
jaitools - - -
jai-ext x - -
imageio-ext x - -
geotools x - -
geowebcache x - -
geoserver x - -
Stage 2 Reduce warnings from Dependency Analysis Tools
Done when code we have control over has addressed dependency analysis warnings (except split packages)
This cannot be automated, and is why we have so many people in the sprint!
  • Resolve Warning: Address warnings from our codebase, many warnings provide clear guidance (will need to save split packages to the next stage.)
  • Upgrade Dependencies: Upgrade dependencies to resolve warnings (should still compatible with Java 8 via mule-release jar or similar.)
Coordination using our spreadsheet will be key as dependency upgrades are transitive to downstream projects.
Stage 3 Module repackage
Done when split-module warnings are resolved, and geotools demo applications can run on the module path.
Add automatic module descriptors, eliminate split packages in library projects, add module-info.java only if needed.
  • Repackage: Repackage each codebase as required to address-split modules
  • Module App: Make sure we can run a true module app depending on the automatic modules
  • Imports: Adjust imports and the like as needed in all projects, try to collect migration scripts to help others do the same.
Discussion:
  • Choice between using eclipse api baseline to generate migration script, or writing sed scripts by hand.
Stage 4 org.opengis repackage
Done when references to org.opengis package are removed
Swich gt-api away from using org.opengis package, upgrade everything else to follow
  • Repackage: Repackage org.opengis interfaces into appropriate org.geotools package
  • EMF Model: Update emf models and regenerate
Discussion:
  • Updating EMF models requires figuring out which version of eclipse was used to generate
Postsprint Activities
  • Blog capturing sprint results and thanking sponsors
  • We would like to issue a milestone release giving downstream projects a chance to migrate ahead of January release candidate.
How to sponsorship
Contributions will be put towards travel costs for sprint participants who would be otherwise unable to attend. Any surplus at the end of the event will be turned over to OSGeo or used for a future code sprint. We have set-up the sprint to minimize travel and accommodation costs.
Sponsors will receive the following benefits / honours:
  • Your logo at the top of this page
  • Mention in project communication (for example the GeoServer 2.15 release announcement)
  • The ability to run on a supported java platform
  • Our gratitude :)
This event provides the following sponsorship levels:
Gold $2500 USD
Silver $1500 USD
Bronze $750 USD
In-Kind In-kind support graciously accepted
This is an official OSGeo event, your contribution counts towards being recognized as an OSGeo Sponsors.
For more information on sponsorship, please contact Jody Garnett, Andrea Aime.
How to Sponsor
  1. Sponsorship is accepted through the Open Source Geospatial Foundation
    • Use OSGeo PayPal link, funds are in USD marked towards "OSGeo Foundation java code sprint".
    • To make alternative arrangements or request an invoice contact OSGeo Treasurer: treasurer@osgeo.org
  2. Once sponsorship is received the OSGeo Treasurer will contact you and the event organizers to acknowledge your sponsorship
    • Please have a logo ready for your organization if you wish to be acknowledged publicly
    • Your event sponsorship, at your request, can contribute towards being recognized as an OSGeo Foundation sponsor
Sponsorship Outreach
We are reaching out to organizations to see if there is interest in sponsorship:
  • Prior sponsors: gaia3d, boundless, ian, geodan, how2map, fossgis, atol, geosolutions, astun
  • Local sponsors: astun, vivid solutions, transient software
If there is a lot of local sponsorship we expect to drag the developers away from the task at hand and meet the local community (at a social evening or similar).
OSGeo Funding Request
The following information is requested by OSGeo Board Code_Sprint_Guidelines, the projects involved indicated that we would be planning a sprint during the 2018 budget process.
It is intended to that OSGeo be recognized as hosting this event, rather than acknowledged as a sponsor.
