Live GIS Add Project
From OSGeo Wiki
Contents |
What gets into OSGeoLive?
We have an emphasis of quality, and we are space constrained on OSGeoLive and so are selective about what is included.
Priority for selecting OSGeoLive projects to package is:
- OSGeo Projects
- OSGeo Projects in incubation
- Stable GeoSpatial Open Source Software being presented in workshops, tutorials, or presentations at FOSS4G
- Other Stable GeoSpatial Open Source Software with established project communities and a wide user base
- It will be ready for the next release in accordance with our schedule
Application Questions
Projects need to provide:
- Project Champion
- Someone who will liaise between the OSGeoLive team and the project and ensures the application remains up to date on OSGeoLive.
- A base #Install_Script for installing onto an Ubuntu Linux based system.
- #Documentation in line with OSGeoLive templates
- Someone who will run and verify the applications works in development releases
- Project Status to be maintained.
If you think you can cover all these criteria for your project, then send an email to the OSGeoLive email list asking if your project is appropriate. When emailing the list, please address the questions in the Live_GIS_Disc_Apply form.
Which version to use?
- Stable, always! LiveGIS users are usually seeing OSGeo newbies and will be turned off by any software bugs.
Install Script
Each project is to write a shell script which installs and configures your stable application into the OSGeoLive Xubuntu.
All install scripts for building the LiveGIS disc shall be licensed as LGPL.
When finished, ask the OSGeoLive team to reference your script from main.sh.
Scripts are stored here: https://svn.osgeo.org/osgeo/livedvd/gisvm/trunk/bin/
The script may be as simple as: install_mapserver.sh, which just
apt-get install mapserver
Projects that haven't been packaged for Ubuntu yet are slightly more complicated:
The uDig package is a good example: install_udig.sh
- 3rd Party Repositories: Create an <app>.list file with your repository in sources.list.d/ in the svn, in your script copy the file to the local machine like
cp -f ../sources.list/ubuntugis.list /etc/apt/sources.list.d/
don't forget to add the repository key like so
apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 68436DDF
Packaging conventions
- sudo: Assume the script is to be executed as root. This means that sudo is only needed if you need to execute a command as e.g. the database user.
- This means that ~/ refers to the directory /home/root/, so you should use ~user/ to reference /home/user/.
- Preferred method is to put the USER_NAME and USER_HOME variables at the top, so these can be easily changed in all scripts if needed.
USER_NAME="user" USER_HOME="/home/$USER_NAME" cp package_readme.txt "$USER_HOME"
- Called twice: Assume that the script will be executed multiple times, (as people may re-run the install process to get it right).
- Make sure that nothing is corrupted if the script runs a second time.
- No Prompts: Try not to have any interactive steps which prompt the user for an answer, as we want the scripts to be run automatically. In particular, try running the script a second time, and see if you get prompted to overwrite files.
- /tmp: Copy all downloads into /tmp/build_<package>/
- Don't delete the /tmp/build_<package> directory afterwards. If the script is re-run, then time and bandwidth is saved by not having to download large files again. Do not do code checkouts or place temporary files in the starting build directory, which is ./bin/ in the live disc's SVN tree. See the "BUILD_DIR" environment variable used in a number of scripts if you later have to refer back to the ../app-conf/ or ../app-data/ relative paths in the live disc's SVN tree.
- Icons: Where appropriate, create an icon on the desktop which loads the application. The file should be called <packagename>.desktop and placed in /home/user/Desktop/ for further processing. The icons will be sorted and the Geospatial menu will be auto-generated from here.
- Install <packagename>.png icon files to the /usr/share/icons/ directory.
- see install_qgis.sh for an example
- Browser bookmarks: If the application is launched from the browser, then include the application in Firefox bookmarks.
- (Todo: How do we do this?)
- wget: When downloading large files using wget, use the "-c" continue command, as it will not re-download files if they already exist, and will continue if one is partially downloaded:
wget -c package.tar.gz
- Do not use -c if there is a chance the file of that name will change on the server. Add "--progress=dot:mega" to the wget command line if the file is at all large.
- Tiny files should use wget's -nv (non-verbose) flag.
- In a similar manner, use "--quiet" when calling qsql.
- mkdir: Use -p (create parents too) option when creating a directory, as it doesn't complain about creating the directory a second time.
mkdir -p <dir>
- Binary files: Do not put large (>5mb) binary files into the SVN repository without asking first. Due to SVN's preservation of history, once they are added they can never be removed, and forever-more clog up the backend database. Subversion is designed to be a source code management tool, not a data warehouse. There is space for large static data files (e.g. sample data) at http://download.osgeo.org/livedvd/data/. Just ask on the mailing list if you'd like to house something there.
Packaging considerations
The criteria used to select applications for the LiveGIS follow.
Technical limitations
Space considerations
- DVD: approx 4.2gb compressed
- USB stick: For a 4gb persistent USB stick with some room left over for user-workspace, 3.2-3.5gb compressed. (This pretty much works out to the DVD version minus the preloaded Mac and Windows installers)
- Virtual Machines: theoretically unlimited, but in practice 20gb uncompressed
So smaller apps (<30mb) of lesser priority may easily slip in under the ire radar, but an external project that wants to use a 25% of the available disc space would be the first to be compromised away.
Memory considerations
Both Virtual Machines, and a LiveDVD images are likely to be constrained by limited memory. So to reduce memory usage. Disk image size is not of major concern, as we can just distribute less data.
The following principles should be followed.
- Do not start applications upon power up. (Ie, don't start deamons, allow users to start them instead).
- Set up examples which, by default, don't depend on other applications. Less applications open, means less memory. Ie, Have GeoServer access a shapefile instead of PostGIS.
- Try to avoid scenarios which write data to disk, as disk space in the Live DVD is stored in RAM, and is not cleared afterward.
File permissions and filesystem user IDs can get garbled during the ISO build process. Therefore a special method is used to ensure that data files which must be read-write can be accessed.
To install a writable data directory or files, change its group to "users" and set the file(s) as group-writable:
adduser $USER_NAME users chmod -R g+w /usr/local/share/<packagename>/data/ chown -R root.users /usr/local/share/<packagename>/data/
and symlink into the user's home directory if necessary.
Setting files to have universal write permission is strongly discouraged. Do not use "chmod 777 -R".
The disc is a busy place, so we must all play nice and take care not step on each others toes.
Changes to the base system
Please don't customize any system level infrastructure which other projects may be relying on. Often there is an /etc/$foo.d/ directory for you to put config additions into. Always put non-.deb packaged custom things in /usr/local not /usr!
Port numbers
To avoid overlaps and conflicts with other packages, please avoid putting web services on common port numbers like 8000 or 8080. Choose a random port between 8000 and 8080, search through the whole documentation for this port number (e.g. "grep -R 8042 doc bin") and only use this number if it isn't mentioned anywhere else. Then add your new port number to your quick guide so that others will find it.
Rasdaman is using ports 7001 (dispatcher), 7002, 7003, etc. (worker processes). The number of workers is fixed in the etc/rasmgr.conf file, at least one is required.
Directory Structure
- /tmp Temporary files (e.g., downloaded archives) go into /tmp. Please create a separate folder for your project.
- /usr/lib application are usually installed into /usr/lib
- /usr/bin things that get executed by the user such as startup scripts or links to them should go into /usr/bin
- /etc/init.d startup/shutdown scripts for services (e.g., postgres, apache, tomcat) are stored in /etc/init.d
- /usr/local/share sample data and documentation goes into /usr/local/share
- /etc config files are stored in /etc
- /home/user user specific config files or working directories can go into /home/user/. However, keep files in /home/user as small as possible as this folder is loaded into memory in the Live DVD. Symlinks into /usr/local can be useful here.
- You are strongly encouraged to use /usr/local/ and /var/local/ for storing non-packaged content.
.deb Packaging
While many packages are installed from a bash script, ideally, applications should be packaged in UbuntuGIS or DebianGIS repositories, or in a Launchpad PPA (e.g. available from the UbuntuGIS repository). Next would be packaged into .debs from your own Ubuntu repository. An official Debian package could be used, but we'd have to rebuild it from source (this takes time but is fairly easy; usually these are already sucked in Ubuntu automatically so it isn't an issue).
If you must build from source, building a .deb package and installing that is preferred to "make install". If you do need to "make install", please set the path prefix to /usr/local/ and ensure that your package does not introduce namespace conflicts.
In practice a number of scripts employ a hybrid approach, with as much as possible installed via official packages, and the occasional plugin compiled from source.
A base set of build-tools are already included, but if you install a bunch of -dev packages to build your app, make sure that you clean them all up after you are done.
Using "gdebi" instead of "dpkg -i" can be useful for installing .deb packages manually, as it ensures that all dependencies are also installed.
Example Datasets
In order to reduce disk space, and to provide consistency between projects, we strongly encourage all projects to make use of the common datasets packaged on OSGeo-Live by the install_gisdata.sh script.
All datasets should be installed into /usr/local/share/data, or if installed elsewhere, there should be a symbolic link into /usr/local/share/data. Data should not be installed in the /home/user directory, as I understand that data in the HOME directory is copied into RAM. (TBD find confirmation of this).
There is a symbolic link from /home/user/data to /usr/local/share/data to make it easy to find from a user's home directory. (Documentation should reference /home/user/data/... ).
Datasets are also available via http://localhost/data/ and http://live.osgeo.org/data/ (which is a symbolic link from /var/www/data to /usr/local/share/data).
Natural Earth
The Natural Earth dataset is the preferred dataset for all examples.
- 1:10m Simple Populated Places. Shapefiles are in /user/data/natural_earth/* and have also been loaded into PostGIS.
- admin_0_countries
- admin_1_states_provinces
- geography_marine_polys
- geography_regions_elevated_points
- geography_regions_polys
- lakes
- land
- ocean
- populated_places_simple
- rivers_lake_centerlines
- urban_areas
- Raster basemap -- Cross Blended Hypso with Shaded Relief and Water 1:50 million, stored in /user/data/natural_earth/HYP_50M_SR_W/*
OpenStreetMap
OpenStreetMap data is loaded into /usr/local/share/data/osm/feature_city.osm
North Carolina
The OSGeo-Geodata collection of geotiffs and shapefiles for Wake County (North Carolina) has been tentatively added for the 5.0 release.
The North Carolina layers can be found in /usr/local/share/data/north_carolina/ (symlinked to ~/data/north_carolina)
Others
If you need another type of data for your examples, please discuss this with us.
Documentation
OSGeo-Live documentation is published at:
- On OSGeo-Live
- http://localhost/ which is stored in /var/www/
- Stable release
- http://live.osgeo.org
- Nightly build
- http://adhoc.osgeo.osuosl.org/livedvd/docs/en/index.html
Application Overview
The Application Overview is a one page marketing page targeted at a someone considering using GeoSpatial Open Source, who may be a GeoSpatial User, a Technical person without much geospatial expertise, or manager with limited GeoSpatial or technical experience. Published Overviews are linked from here: http://live.osgeo.org/en/overview/overview.html
The source Overviews are written in RST wiki format and built using sphinx. Source documents are to be stored here: https://svn.osgeo.org/osgeo/livedvd/gisvm/trunk/doc/overview/en/<application>_overview.rst . They should follow the structure and style of the reference Overview, which has lots of helpful comments, at https://svn.osgeo.org/osgeo/livedvd/gisvm/trunk/doc/en/overview/postgis_overview.rst
The Overviews are currently published as HTML pages. In future we intend to also create 1 page PDFs, (to hand out as a flier at conferences, and as a page in the OSGeo Book of projects), and as Word/OpenOffice (to be cut and pasted into project proposals and articles which usually use these formats).
Overviews also require:
- an image for the application, usually a screen shot or collage of screen shots, as per Screen Shot.
- A project logo as per #Logo
Try printing the html page from the browser, and ensure that the page is less than one page long. (The less words you write, the more people will read your documentation.)
Once finished, note your project's overview status="draft" in the OSGeo-Live project status at: http://spreadsheets.google.com/ccc?key=0Al9zh8DjmU_RdGIzd0VLLTBpQVJuNVlHMlBWSDhKLXc&hl=en_GB#gid=5 and email live-demo@lists.osgeo.org noting your documentation is ready for review. Once reviewed, the status is moved to "complete" and is ready for translation.
Application Quick Start
The Application Quick Start defines detailed steps, with screen shots, for a new user to run one of the application's core functions. It should be able to be run in 5 to 10 minutes.
Try to make use of a friendly, conversational writing style, similar to the way a tutor would talk a class through an example. The quickstarts for R and GeoServer do this very well.
Source documentation is written in RST wiki format, is built using sphinx, and is stored here: https://svn.osgeo.org/osgeo/livedvd/gisvm/trunk/doc/en/quickstart/<application>_quickstart.rst
The reference quickstart, which includes structure guidelines and with tips on how to fill in the quickstart is here: https://svn.osgeo.org/osgeo/livedvd/gisvm/trunk/doc/en/overview/udig_quickstart.rst and is published here: http://live.osgeo.org/en/quickstart/udig_quickstart.html
In order to reduce disk space, and maintain consistency between applications, we request that all examples make use of the common #Example_Datasets. If the datasets don't cover your requirements, discuss this with us and we may add another suitable common dataset.
Applications are expected to include screen shots for each major step in the quickstart, as per Screen Shot.
Once finished, note your project's quickstart status="draft" in the OSGeo-Live project status at: http://spreadsheets.google.com/ccc?key=0Al9zh8DjmU_RdGIzd0VLLTBpQVJuNVlHMlBWSDhKLXc&hl=en_GB#gid=5 and email live-demo@lists.osgeo.org noting your documentation is ready for review. Once reviewed, the status is moved to "complete" and is ready for translation.
Logo
The Project's logo is used in the headers of documentation (like Project Overviews, QuickStarts, Powerpoint presentations etc, and as icons on the OSGeo-Live Desktop. Hence there are a few different requirements for the logo.
- Header logo
- Stored here: https://svn.osgeo.org/osgeo/livedvd/gisvm/trunk/doc/images/project_logos
- Filename should be "logo-<projectname>.png"
- Should have a transparent background (not white)
- Preferably stored in size 125x125 pixels (for use in Project Overview and QuickStarts)
- Should preferably be in PNG format
- For PNGs please run a program like pngcrush or optipng to reduce the size of the image without degrading quality.
- Preferably also available as SVG, stored as "logo-<projectname>.svg"
- Desktop logo
- We are still to define the requirements for creating a desktop logo. They will likely include:
- A 32x32-pixel XPM icon for use by the Debian menus
- A 48x48-pixel PNG icon for use by freedesktop.org menus
Screen Shot
Project overviews include an image, which is usually a screen shot, or collage of screen shorts. Quickstarts include screen shots for each significant step.
- Screen shots can be taken using Shutter (on linux) or Greenshot (on windows).
- Screen shots should be taken from a 1024x768 display, and stored here: https://svn.osgeo.org/osgeo/livedvd/gisvm/trunk/doc/images/screenshots/1024x768
- For Quickstarts, consider marking up the image to explain the current steps. Eg: Add circled numbers: 1, 2, 3 or draw an oval around buttons being described. This is very easy to do using the "Edit" tab in the Shutter program, which provides these drawing icons to add. Tutorials augmented with detailed and pertinent images make it easy for the reader to follow what is going on. Extra time spent on an image pays off big in comprehension (you need more than just a course screen dump). Lines, numbering, highlights, boxes and annotations all help direct a user's focus to those areas which are important.
- Screenshots with large areas of constant color (menus, etc.) should be in PNG format, screenshots containing large areas of imagery (satellite images, shaded relief DEMs, etc.) should be in JPEG format.
- For PNGs please run a program like pngcrush to reduce the size of the image without degrading quality.
Extra Documentation
Some projects link to extra documentation, stored as PDFs or similar, or alternatively provide example applications. These should be referenced in documentation via a relative link such than it can viewed from:
http://localhost/<application>/... or http://live.osgeo.org/<application>/...
This should typically be achieved by creating a symbolic link from /var/www/<application> to /usr/local/share/doc/<application>
Publishing Documentation
The following web service is useful for checking reST formatting: http://rst.ninjs.org/
For a more comprehensive test, set up the reST processor, sphinx:
- (you will have to have Sphinx 0.6.4 or greater installed, it's in the python-sphinx Debian package)
sudo apt-get install python-sphinx
cd osgeo/livedvd/gisvm/trunk/doc/ make html
You can then view the results in:
osgeo/livedvd/gisvm/trunk/doc/_build/*.html
Testing procedure
Provide test steps for your application as per the Live GIS Disc Testing wiki page.
Once the application has been included into a release candidate, ensure the test steps are executed and work on the release candidate. Write up the results as per the Live GIS Disc Testing wiki page.
Translations
For details on how to translate, refer to Live GIS Translate
