Live GIS Disc:mapfile for mapserver
From OSGeo Wiki
to respect the liveDVD configuration this mapfile should be put as:
/home/demo/mapserver/test.map
WMS calls
- getCapabilities: http://localhost/cgi-bin/mapserv?map=/home/demo/mapserver/test.map&request=getCapabilities&service=WMS&version=1.1.1
mapfile code
# (Created with PyQgis MapServer Export plugin)
MAP
NAME test map
# Map image size
SIZE 400 400
UNITS dd
EXTENT -2260028.875000 -354486.541988 1583700.875000 3150588.604488
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
# Background color for the map canvas -- change as desired
IMAGECOLOR 192 192 192
IMAGEQUALITY 95
IMAGETYPE png
OUTPUTFORMAT
NAME png
DRIVER 'GD/PNG'
MIMETYPE 'image/png'
#IMAGEMODE PC256
EXTENSION 'png'
END
# Legend
LEGEND
IMAGECOLOR 255 255 255
STATUS ON
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
END
# Web interface definition. Only the template parameter
# is required to display a map. See MapServer documentation
WEB
# Set IMAGEPATH to the path where MapServer should
# write its output.
IMAGEPATH '/tmp/'
# Set IMAGEURL to the url that points to IMAGEPATH
# as defined in your web server configuration
IMAGEURL '/tmp/'
# WMS server settings
METADATA
'wms_title' 'test map'
'wms_onlineresource' 'http://localhost/cgi-bin/mapserv?map=/home/demo/mapserver/test.map&'
'wms_srs' 'EPSG:4326'
END
#Scale range at which web interface will operate
# Template and header/footer settings
# Only the template parameter is required to display a map. See MapServer documentation
END
LAYER
NAME 'ak_shade'
TYPE RASTER
DATA '/home/demo/qgis_sample_data/ak_shade.tif'
METADATA
'wms_title' 'ak_shade'
END
STATUS DEFAULT
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
END
LAYER
NAME 'alaska'
TYPE POLYGON
DATA '/home/demo/qgis_sample_data/alaska.shp'
METADATA
'wms_title' 'alaska'
END
STATUS DEFAULT
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
CLASS
NAME 'alaska'
STYLE
SYMBOL 0
SIZE 3
OUTLINECOLOR 0 0 0
COLOR 111 158 72
END
END
END
LAYER
NAME 'canada'
TYPE POLYGON
DATA '/home/demo/qgis_sample_data/canada.shp'
METADATA
'wms_title' 'canada'
END
STATUS DEFAULT
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
CLASS
NAME 'canada'
STYLE
SYMBOL 0
SIZE 3
OUTLINECOLOR 0 0 0
COLOR 114 58 48
END
END
END
LAYER
NAME 'lakes'
TYPE POLYGON
DATA '/home/demo/qgis_sample_data/lakes.shp'
METADATA
'wms_title' 'lakes'
END
STATUS DEFAULT
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
CLASS
NAME 'lakes'
STYLE
SYMBOL 0
SIZE 3
OUTLINECOLOR 0 0 0
COLOR 71 142 107
END
END
END
LAYER
NAME 'majrivers'
TYPE LINE
DATA '/home/demo/qgis_sample_data/majrivers.shp'
METADATA
'wms_title' 'majrivers'
END
STATUS DEFAULT
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
CLASS
NAME 'majrivers'
STYLE
SYMBOL 0
SIZE 3
OUTLINECOLOR 44 232 27
COLOR 0 0 0
END
END
END
LAYER
NAME 'russia'
TYPE POLYGON
DATA '/home/demo/qgis_sample_data/russia.shp'
METADATA
'wms_title' 'russia'
END
STATUS DEFAULT
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
CLASS
NAME 'russia'
STYLE
SYMBOL 0
SIZE 3
OUTLINECOLOR 0 0 0
COLOR 33 127 194
END
END
END
END
