Live GIS Disc Press Release 77
From OSGeo
What's in the OSGeo-Live 11.0 reboot?
29 May 2017
In line with the OSGeo-Live reboot [1] we have identified the following actions:
We will only support a 64 bit distribution, (32 bit will be built but not tested or officially supported).
We will no longer provide:
  • Windows installers,
  • Write ups for OGC Standards,
  • Write ups for libraries without a user interface (on a case-by-case basis)
Stray projects: We haven't got a point of contact for these projects. If you know something about this project, and can help review docs, then please consider adopting the project. Without a volunteer, we will need to consider retiring them from OSGeo-Live. Work commitment is low, kudos and karma very high :)
  • openlayers
  • osgearth
  • gmt
  • iris
  • jupyter
  • JOSM ( OpenStreetMap editor )
  • proj4
  • mb-system
  • zygrib
Projects recommended to be retired from OSGeo-Live:
  • geokettle
  • geomajas
  • javaworldwind
  • kosmo
  • mapnik
  • pywps (quickstart broken)
  • sahana
  • tinyows
  • ushahidi
  • viking
Remaining projects:
  • Most projects have at least minor tweaks required for the docs, some have outright errors.
  • We are asking each project to, check their project overview, run the application on an OSGeo-Live VM (10.5 or a recent nightly build), run every step of the quickstart, update if required, and tell us when done.
  • Once verified, we will add the project back into the OSGeo-Live 11.0 builds.
  • We will call on all projects to test their projects and quickstarts again in an OSGeo-Live 11.0 beta.
For specific project comments, see the OSGeo-Live status spreadsheet, column T "11.0 Comment", and column U "10.5 Doc Review".
[1] https://wiki.osgeo.org/wiki/Live_GIS_Disc_Press_Release_75
[2] https://docs.google.com/spreadsheets/d/1Q5BaEgQtgw4O1bXyeWMlM8XtAOhUgcjZ7Y2O0FZc2H0/edit?hl=en_GB#gid=2014800150
Key Milestones
5-Jun-2017 OSGeo-Live Feature Freeze (final application versions installed)
19-Jun-2017 OSGeo-Live delivered to UAT (final application versions installed - Beta stage)
24-Jul-2017 OSGeo-Live Final ISO
14-Aug-2017 FOSS4G 2017 Boston
... full schedule
About OSGeo-Live
OSGeo-Live (http://live.osgeo.org) is a Lubuntu based distribution of Geospatial Open Source Software, available via a Live DVD, Virtual Machine and USB. You can use OSGeo-Live to try a wide variety of open source geospatial software without installing anything.
