Mapbender at ProjectsVM
From OSGeo
Startpage
Server Overview
Status
  • 2010-08-08 configuration is done, trunk and mapbender 2.6.2 available, demos served from trunk
Participants
Services on this Blade
  • Mapbender
  • PostgreSQL/PostGIS
  • svn
  • gettext
  • every Mapbender version is presented by http://projects.mapbender.osgeo.org/
    • if you need root access to the demo mapbender ask the participants (see above)
  • the home for the Mapbender packages is: /osgeo/mapbender/
  • the update of the mapbender version is done by svn
  • we offer a portal function so user can login and try the applications
  • as adminstrative database we use PostgreSQl/PostGIS
Apache
  • /etc/apache2/sites_available/projects.mapbender.osgeo.conf
  • logfiles at:
 ErrorLog /var/log/apache2/projects.mapbender.osgeo.org-error_log
 CustomLog /var/log/apache2/projects.mapbender.osgeo.org-access_log combined
How to setup the current mapbender version
Mapbender Database
  • use the install.sh
  • take the last version as template (check the guis first - everything still allright?)
  • (postgis_template)
directory and svn checkout
cd /osgeo/mapbender
sudo bash
mkdir mapbender_2.6
svn co https://svn.osgeo.org/mapbender/branches/2.6 /osgeo/mapbender/mapbender_2.6/
cd /osgeo/mapbender/mapbender_2.6/resources/db/
chmod u+x install_2.6.sh
./install_2.6.sh --> use template_postgis as database template
for update use:
cd /osgeo/mapbender/xx
sudo bash
svn up https://svn.osgeo.org/mapbender/branches/2.6 /osgeo/mapbender/mapbender_2.6/
chmod u+x update.sh
./update.sh
Change the root password
  • the root password has to be changed to the password the devs defined (ask administrators)
Create user demo
  • create user demo password demo
  • assign public applications to this user
create the symbolic link current_release with ln -s ...
  • drop current symbolic link
rm /osgeo/mapbender/current_release
  • create it again with path to actual mapbender version
ln -s /osgeo/mapbender/mapbender/mapbender_2.5 /osgeo/mapbender/current_release
create new link in html start page index.html
vim /osgeo/mapbender/index.html
