Mapbender at mapbender.telascience.org
From OSGeo
Jump to: navigation, search
Status of mapbender.telascience.org
  • 2010-05-19: Down
  • 2010-05-29: Up
  • 2010-06-03: Down
  • 2010-06-04: Up
This server is internally known as xblade10-2 and is mapped to IP 198.202.74.215. It runs:
Participants
Services on this Blade
  • Mapbender
  • PostgreSQL/PostGIS
  • every Mapbender version is presented on this server http://mapbender.telascience.org/
    • if you need root access to the demo mapbender ask the participants (see above)
  • the home for the Mapbender packages is:
/var/www/html/mapbender/
  • the update of the mapbender version is done by svn
  • we offer a portal function so user can login and try the applications
  • as adminstrative database we use PostgreSQl/PostGIS
Apache
  • we added an ALIAS for each Mapbender versions:
  • /etc/httpd/conf/httpd.conf
How to setup the current mapbender version
Mapbender Database
  • create the database for the next version
  • take the last version as template (check the guis first - everything still allright?)
createdb -U postgres  -E UTF8 -T mapbender_2.5 mapbender_2.6
(postgis_template)
directory and svn checkout
cd /var/www/html/mapbender
sudo bash
mkdir mapbender_2.5
svn co https://svn.osgeo.org/mapbender/branches/2.5 /var/www/html/mapbender/mapbender_2.5/
-- for update use: svn up https://svn.osgeo.org/mapbender/branches/2.5 /var/www/html/mapbender/mapbender_2.5/
chown apache /var/www/html/mapbender/mapbender_2.5/log
chown apache /var/www/html/mapbender/mapbender_2.5/http/tmp
rm -r /var/www/html/mapbender/mapbender_2.5/http/tools
add the alias to Apache httpd.conf
vi /etc/httpd/conf/httpd.conf
Alias /mapbender_2.5      /var/www/html/mapbender/mapbender_2.5/http/
restart Apache
/usr/sbin/apachectl configtest
/usr/sbin/apachectl graceful
create mapbender.conf and configure it
 cp /var/www/html/mapbender/mapbender_2.5/mapbender.conf-dist  /var/www/html/mapbender/mapbender_2.5/mapbender.conf
  • if possible use the Mapbender database which is already in use with the older Mapbender Verson
  • vor Mapbender 2.5 I (AE) had to create a new Mapbender database (mapbender_2.5)
create the symbolic link current_release with ln -s ...
  • drop current symbolic link
rm /var/www/html/mapbender/current_release
  • create it again with path to actual mapbender version
ln -s /var/www/html/mapbender/mapbender_2.5 /var/www/html/mapbender/current_release
create new link in html start page index.html http://mapbender.telascience.org/
vim /var/www/html/mapbender/index.html
