SAC Meeting 2019-08
From OSGeo
Where and When
  • in IRC on Freenode, channel: osgeo-sac
Meetings Happened
2019-08-01 Transcript
2019-08-15 Transcript
Agenda
  • osgeo4 #1940 - osgeo4 has been shutoff since all VMS have been moved off of it. we need to put in new drives so we can reformat it reformat and install lxd as a backup for osgeo7 and also so we can install experimental lxd containers like drone bots etc.
STATUS: 2019-08-29 OSUOSL has installed the new hardware in osgeo4 and installed Ubuntu 18.04. Regina confirmed she has ssh access, but no KVM access. Asked for a similar KVM access we have for osgeo7 whcih is via the OSUOSL private domain http://osgeo4.osuosl.oob
  • #2314 Both osgeo3 and osgeo 4 need new power supplies
STATUS: New power supplies have been ordered, are they in place? In place for osgeo4, not sure if anything has been done to osgeo3 since I assume they'd need to take it down to do maintenance.
Since last we spoke secure, adhoc, old-web (which houses id.osgeo.org) have been moved to osgeo7. adhoc.osgeo.osuosl.org now points to osgeo7 Also setup a grass container which neteler is configuring to replace the current grass on osgeo6 (WIP at https://nbozon.github.io/GRASS-GIS/)
-- Alex noted that the libavatar calls are each taking a second each so that could be one bottleneck
  • TODO: Setup Bacula (need some thoughts on best way to go about this since osgeo7 is not setup quite the same and for some containers seems overkill to install a bacular fd client
  • TODO: Wiki is old and needs to be replaced the MySQL 5.5 EOL'd a couple of years ago for one.
  • TODO: 2339 Load balance download.osgeo.org using ftp.osuosl.org/osgeo/download - jef mentioned this Nginx load balancing redirect
  • DONE: installing patches and rebooting host made it work again. jef noticed /proc/uptime no longer works on osgeo containers. osgeo7 is asking for reboot which will probably fix the issue. I noted rebooting a container fixes the issue for that container.
Budget
  • OSUOSL donation and FunToo donation are we set?
    • FunToo submitted to monthly payment plan, did treasurer figure it out?
    • OSUOSL, need to submit request to treasurer. - Request was made June 27, need confirmation
System Contracts
  • DONE Regina -- Second contract in place
  • LDAP+SSH Keys
  • Migrating OSGeo Wiki Logins to OSGeo LDAP
Open tickets needing attention
Other topics
  • ``DONE`` geotools should create new keys and supply the public key.
  • DONE: moved cvvergara to bureaucrat group
SAC main page
