Shptree notes
From OSGeo Wiki
Jump to: navigation, search
Contents
shptree Processing Notes
(for the Benchmarking_2010 exercise)
shptree Depth
No depth parameter was used for the shptree command, which means the shptree code would determine the optimal depth. The determined depths were:
file depth
building 21
contour-0 16
contour-1 17
contour-2 17
contour-3 17
contour-4 17
contour-5 15
contour-6 17
contour-7 17
industry 17
motorway 10
point-labels-for-geometry 15
point-labels-no-geometry 18
ramp 14
road 14
settlement 16
track 16
Verifying the qix file
  • shptreetst utility was used to verify the integrity of qix file
  • you should see a message like:
 $ shptreetst contour-0.qix
 This new LSB index supports a shapefile with 221671 shapes, 16 depth
 shapes 0, node 4, -8.187613,36.166759,3.274251,43.666687
 shapes 0, node 4, -8.187613,36.166759,-1.883588,40.291719
 shapes 0, node 4, -8.187613,36.166759,-4.720399,38.435487
 shapes 0, node 1, -8.187613,36.166759,-6.280646,37.414560
 shapes 0, node 2, -7.329478,36.728269,-6.280646,37.414560
 read entire file now at quad box rec 20 file pos 1000
 using last read box as a search
 result of rectangle search was
   86554, 86580, 86586, 86598, 86638, 86641, 86642, 86643, 86660, 86667, 195862, 195895, 195901, 195903, 195926, 196873, 197711,
buildings.shp
  • shptreetst building.qix caused a Segmentation fault initially on our BenchmarkB Linux server (with 8GB RAM)
  • to solve this we...
Personal tools
