SAC:Admin and Troubleshooting
From OSGeo Wiki
Contents |
Troubleshooting
- SAC:Primary Administrators (with contact info)
- Discuss issues in irc (#telascience)
VM hanging on OSUOSL
see OSL for how to open a ticket with OSUOSL's support
LDAP Server Down
The LDAP server runs on .220, and if it needs to be restarted it can be done as root with the command:
/opt/fedora/slapd-ldapt/start-slapd
Peer1 LDAP Server Hanging
If there is a power outage like there was on 2-20-07, slapd's database will need to be recovered.
sudo /usr/sbin/slapd_db_recover -h /var/lib/ldap/osgeo2
MySQL Cleanup for Drupal
If a report in drupal starts saying a table is crashed and needs repair, log into mysql and run the following, for example for the cache table:
REPAIR TABLE cache QUICK;
Entire www.osgeo.org down (PEER1)
- ISP/DNS problem: what to do? do we need to call anyone?
- hardware reset: Contact SAC:Primary Administrators. One option is a power cycle on the UPS to restart osgeo.org, using the "Reboot Immediate" item on the UPS.
TODO: Define rescue plan with responsible people - see also SAC:Primary Administrators
telascience blade(s) down
... reinstall stuff elsewhere ...
Contact User with Shell Access
If services or o/s need restarting or something else needs emergency attention contact one of the following people with shell access directly:
- Contact SAC:Primary Administrators
PEER 1 Trouble Ticket Process
TODO: add details here or point to elsewhere?
