SAC Service Status
From OSGeo
Infrastructure of OSGeo System Administration Committee (SAC)
For emergency plans see: SAC:Admin and Troubleshooting
Servers at OSL
Open Source Labs - 6 physical machines that are lxd hosts containing x virtual machines/containers. 1 is currently shutdown
history:
  • 7 physical machines of which 5 ar lxd hosts containing x virtual machines/containers.
  • As part of migration of data center 2025)
Logging into Physical Machines
Currently we do not have physical machines under LDAP control.
All SAC administrators have LDAP auth to the OSL Machines.
To ssh into a server using your LDAP account, you can do the following replacing your_osgeo_login with your OSGeo login and vmname with the vm name of the server at OSL.
 ssh your_osgeo_login@servername.osgeo.osuosl.org
When prompted for password, use your OSGeo Login password.
SAC:Primary Administrators also have ssh key access in case LDAP is down and that will also apply to the physical machines. Worst case scenario use the information on Open Source Labs to file a ticket (SAC members only). Direct connection to virtual machines is by appending it's vm alias to .osgeo.osuosl.org.
Logging into LXD Hosts
osgeo4, osgeo7, osgeo8, and osgeo9 are all Ubuntu servers running LXD. LXD is a management system for LXC containers and QEMU VMS. LXD has a channel that covers its features.
To directly access the host, you go thru port 2222
  ssh tech_dev@server_name.osgeo.osuosl.org -p 2222
Only SAC:Primary Administrators have their ssh key installed under that account. In order to access via KVM of these in event servers do not come up on a reboot, you need to go thru OSU OSL OpenVPN. To get an OpenVPN account, you need to put in a support ticket to support@osuosl.org. In order to qualify for an OpenVPN account, you need to be an OSGeo SAC administrator. You will also need to install OpenVPN client) to use your OpenVPN account.
Each host on the private KVM side is named https://osgeo8.osuosl.oob -- where replace osgeo8 with the relevant host. The .oob is the private network, so doesn't work unless you are connected to via OpenVPN.
The browser interface is sometimes clunky, so you might want to use ipmitool installable on linux/unix or wsl using relevant package manager. KVM passwords are stored in SAC password-store.
A convenient block to add to your ~/.ssh/config to easily login to osgeo's LXD/Incus hosts follows:
   Host osgeo? osgeo??
     User tech_dev
     HostName %h.osgeo.osuosl.org
     Port 2222
Then you would be able to log into those hosts with commands like:
   ssh osgeo7
Logging into LXD/Incus Containers and VMs
A convenient block to add to your ~/.ssh/config to easily login to osgeo's LXD hosted containers and vms is the following:
  # This stanza is only needed if you have an IdentityFile configured below.
  # The IdentityFile from a target host is not automatically applied to the hop host, so we need to make it explicit:
  Host hop.*.osgeo.org
    IdentityFile "path/to/your/private/key"
  Host osgeo*-*
    ProxyCommand ssh yourusername@hop.$(sed -e "s/-.*//" <<< "%h").osgeo.org -W $(sed -e "s/^osgeo[^-*]-//" <<< "%h"):%p
    # this is only needed if you you use different private keys for different servers
Then you'll be able to access a LXC Container or QEMU VM on machine `osgeo9` with:
  ssh yourusername@osgeo9-matrix
And one on machine `osgeo7` with:
  ssh yourusername@osgeo7-download
Note you still need to know where each LXC host is hosted... See successive sections to know what's on which machine.
Troubleshooting: In case of "Permission denied (publickey)." after an update to a modern openSSH version, it might well be that your ssh key (RSH key) is disabled in your client in favour of more modern cyphers.
Ugly workaround: add one line `PubkeyAcceptedKeyTypes ...` in `.ssh/config`, to re-enable RSA keys for now (consider to generate a new key):
 vim .ssh/config
 Host *
    PubkeyAcceptedKeyTypes +ssh-rsa
... but better read e.g. here!
osgeo 6
This was reformated March 2026 to be incus host See osgeo6
services running on osgeo6
hop
hop.osgeo6.osgeo.org - this is the jump host to access the instances on osgeo6
nginx
Proxies all http and https traffic to instances on this host
secure (LDAP )
secure -- ldap.osgeo.org SAC:LDAP used for ldap service (a rebuild of old secure.osgeo.osuosl.org) now on Debian 11 Moved from osgeo9
  • ldap.osgeo.org
ldap-web
Currently housing https://id.osgeo.org/ for LDAP management. Deployed via ansible Moved from osgeo9
  • id.osgeo.org
jitsi
See SAC:Jitsi (for video meetings) - moved from osgeo9 https://meet.osgeo.org
wordpress
See SAC:Wordpress www.osgeo.org
pretalx
Ubuntu 20.04 with OSGeo LDAP and Docker installed. pretalx software runs in Docker. https://talks.osgeo.org - for OSGeo Talk collection and voting See Pretalx
weblate
Container Name: weblate (for doc translation)
Houses: https://weblate.osgeo.org (for document translation to different languages)
For further details refer to SAC:Weblate
osgeo 8
Server added April 2021, donated by OpenStreetMap project.
Likely machine: https://web.archive.org/web/20191112203036/https://hardware.openstreetmap.org/servers/stormfly-01.openstreetmap.org/
LXD host
Configuration Details
Services running on osgeo8
hop
hop.osgeo8.osgeo.org - jump host for accessing containers/vms on osgeo8
nginx
http, https Proxy for all containers on osgeo8 and also provides mirror proxy for download.osgeo.org
geoserver-cite
Houses OGC site certification for geoserver https://cite.geoserver.org {plan to move to osgeo10)
robe-ansible-dev
Container Name: robe-ansible-dev, has ansible 2.9.27 installed and all plugins needed to manage OSGeo ansible infrastructure. DEPRECATED, use `ansible-dev`
pretalx-staging
Container Name: pretalx-staging - used primarily for experimenting with changes to talks.osgeo.org (pretalx on osgeo9) like testing out Docker builds and software upgrade etc, before applying to talks.osgeo.org. - https://talks.staging.osgeo.org
wordpress-dev
Container Name: wordpress-dev - used primarily for osgeo.org main website development - https://staging.www.osgeo.org, https://dev.www.osgeo.org
wiki-staging
Container Name: wiki-staging - used primarily for upgrade changes to wiki.osgeo.org like testing out OS and software upgrade etc before applying to wiki.osgeo.org. - https://staging.wiki.osgeo.org. The construction of this container is managed by sac ansible-deployment.
tracsvn-dev
Container Name: tracsvn-dev - This is a 2019-09-05 lxd2pc image of tracsvn.osgeo.osuosl.org (now on osgeo7 as tracsvn) used primarily for experimenting like testing out OS, git and software upgrade etc before appying to production. -- https://dev.git.osgeo.org, https://dev.tracsvn.osgeo.org Has the following sites: https://dev.trac.osgeo.org, https://dev.git.osgeo.org/gitea, https://dev.svn.osgeo.org.
It was upgraded to Debian 11 on 2024-08-21.
osgeo 9
Likely machine: https://web.archive.org/web/20191112203042/https://hardware.openstreetmap.org/servers/stormfly-02.openstreetmap.org/
Is an LXD host. Also Stores lxd images used by other lxd hosts.
Services running on osgeo9
hop
hop.osgeo9.osgeo.org. For LDAP users allows them to hop thru to get to other containers.
nextcloud
https://nextcloud.osgeo.org
Ubuntu 22.04 LXD/nginx/postgresql 14 container for document sharing similar to dropbox/google drive - nextcloud.lxd - https://nextcloud.osgeo.org Nextcloud Setup
home of https://nextcloud.osgeo.org This server does not use ssh osgeo-ldap as it was the first container built. However nextcloud.osgeo.org does authenticate with osgeo ldap.
TODO: add special page for this
nginx
nginx (for web proxy of traffic of osgeo9 containers) additional mirror proxy for download.osgeo.org
adventure (WIP)
https://adventure.osgeo.org runs https://github.com/thecodingmachine/workadventure software
woodie-client
a ci bot for woodie.osgeo.org which is used for git.osgeo.org/gitea ci jobs
limesurvey
Debian 10, PostgreSQL 13, PHP 8 with ldap/ssh. https://limesurvey.osgeo.org Setup detailed on limesurvey container
mail
mailman: lists.osgeo.org mail.osgeo.org tilechache web: tilecache.osgeo.org mailserver: postfix
matrix
Container Name: matrix - lxd container with ldap/ssh. Hosts Matrix homeserver (SAC:MatrixSynapse) and IRC bridges (SAC:Heisenbridge)
https://gitea.osgeo.org/sac/osgeo9/wiki/matrix-container for full detail on how the container was set up
pixelfed
SHUT OFF (both container and website) cause of lack of interest. Container is still there. Pixelfed instance reachable on https://photo.osgeo.org to house community photos
peertube
Peertube instance reachable on https://video.osgeo.org
geo-docs container
Houses:
wiki
See OSGeo Wiki
mail
Hosts: lists.osgeo.org, mail.osgeo.org and a few other services. See Mail server for more details.
osgeo 10
Server added March 2026, donated by OSUOSL. This is an incus host
Services running on osgeo10
hop
hop.osgeo10.osgeo.org. For LDAP users allows them to hop thru to get to other instances on this machine.
bessie
FreeBSD VM jenkins ci used by PostGIS project
docker-universal
VM Used by postgis jenkins for building docker images
download-cache
https://download-cache.osgeo.org #this syncs with download.osgeo.org for backup
See Download Server
nginx
Acts as nginx proxy to all sites on instances of this server
discourse
See SAC:Discourse
grass
https://grass.osgeo.org upgraded to Trixie debian 13.
GRASS GIS server
Current DNS name: grass.osgeo.org
Web: Apache + Hugo (generated through cronjob from https://github.com/OSGeo/grass-website/), see https://github.com/OSGeo/grass-addons/tree/grass8/utils/cronjobs_osgeo_lxd
`unattended-upgrades` for automatic installation of security upgrades is installed and running
ssh: reachable via jumphost.
grass-wiki
See SAC:GrassWiki (in 2026 moved to osgeo10)
woodie-client-vm
Separate agent for woodie-server, this one is a true VM rather than container.
woodie-server
https://woodie.osgeo.org See Woodie
meshcentral
https://remote.osgeo.org #for workshop osgeolive vms as needed
This is a remoting tool currently setup to test livecd vms via a web browser.
companion vms osgeolive-17-n as needed currently 2
osgeo 7
Server added June 2018. Intended to replace osgeo3 and old osgeo4 (before reformat). See Osgeo7 for configuration details.
Container setup of all the osgeo7 servers is located in https://git.osgeo.org/gitea/sac/osgeo7/wiki/_pages
Running LXD 3 snap based container management -- LXD version 3.17 as of 2019-09-15
Accessing osgeo7 containers via ssh
Only the download.osgeo.org is directly exposed ssh via port 22. To access the other containers, you can tunnel thru download.osgeo.org -- You need to be in the shell group to be able to access download and the other servers. If you are not already put in a SAC Ticket Request. You also need to have your public key registered. To do so edit your profile [1] (and put in your public key)
A convenient block to add to your own `.ssh/config` file follows:
Host osgeo7-*
  ProxyCommand ssh your_osgeo_id@hop.osgeo7.osgeo.org -W $(sed -e "s/^osgeo7-//;s/$/.lxd/" <<< "%h"):%p
With the above in place, you can connect to any container using:
 ssh your_id@osgeo7-<container_name>
 vim .ssh/config
 Host *
Services on osgeo7
Monitor
debian10 lxd container with ldap/ssh. https://monitor.osgeo.org (houses grafana dashboard (for all servers) and prometheus server for osgeo3 containers and pulls basic container metrics using node exporters pulled via prometheus servers. Requirs ldap to log into the web console.
Configuring servers for monitoring is detailed Git Prometheus Config
Download
See Download Server
gallery
See Gallery Container
live
Home of live.osgeo.org ; Running Ubuntu 24.04.3 LTS with OSGeo LDAP SSH
mapserver
See MapServer_at_osgeo7
nexus (repo.osgeo.org, docker.osgeo.org)
See SAC:Repo this is a debian 10 lxd container running docker 19. It currently has one docker container running within it called nexus -- exposed as repo.osgeo.org on nginx.
Also exposed as project dockers for pushing images: postgis-docker.osgeo.org, geoserver-docker.osgeo.org, geos-docker.osgeo.org, sac-docker.osgeo.org
nginx
Proxy that routes all http/https traffic for the other containers (can be accessed via osgeo7 host lxc or ubuntu@osgeo7-nginx if your key is installed on ubuntu user). The nginx container holds the letsencrypt https SSL certs for all the containers and handles the renewal of the letsencrypt certs using certbot renew cronjob. Prometheus server to collect all monitoring logs from OSGeo7 (only accessible by osgeo3), these get queried via monitor.osgeo.org (running on osgeo3) via grafana server.
tracsvn (trac, svn, git)
Home of Trac, Git and Subversion services.
See TracSVN for full details.
photoprism
Picture gallery. Syncs with https://nextcloud.osgeo.org But pictures are shown here https://photoprism.osgeo.org
old-wiki (stopped)
This used to be housed on osgeo3, and was moved 2019-09-14 to osgeo7 as old-wiki container. wiki.osgeo.org moved back to osgeo3 on 2020-05-22 and in wiki container. The wiki container is a complete rebuild with files and database restored and upgraded. Refer to the osgeo3 section for more details.
old wiki container -- used for wiki service (it is an lxd2pc created image of wiki.osgeo.osuosl.org VM that was on osgeo3)
See OSGeo Wiki
nextcloud-ubuntu (stopped)
Moved to osgeo9
dronie-server
See Dronie
old-projects (stopped)
-- this is the old projects.osgeo.osuosl.org migrated from osgeo4 as an lxd container, so more or less the same as it was before, with the exception that all the websites are now proxied thru the nginx container. Websites on it are community-review.foss4g.org and spatialreference.org
To access you need to go thru download.osgeo.org -> old-projects
old-web (stopped)
The old web.osgeo.osuosl.org (was on osgeo3)
  • mapguide.osgeo.org
old-webextra
This is a replica of webextra.osgeo.osuosl.org that was hosted on osgeo3
Started move on November 29th 2019 and completed December 8th, 2019
  • foss4g.org
  • europe.foss4g.org
  • video.foss4g.org
  • planet.osgeo.org
  • various old foss4g.org years
  • live.osgeo.org moved to dedicated container
  • journal.osgeo.org (not sure what this is for, should be retired?)
  • vmap0.tiles.osgeo.org #removed site
Information from webextra on osgeo3
    • Retired December 8th, 2019 -- and moved to osgeo7 as container old-webextra
Container Name: pycsw
osgeo7 decommissioned containers
old-adhoc
SHUTOFF as of 2022-01-29
old-adhoc -- this is the old adhoc.osgeo.osuosl.org migrated 2019-05-08 from osgeo4 as an lxd container. Used by osgeo-live for there test docs and by grass for earthquake, and mapserver for demo. Note that there is a new live (container that osgeo-live will more to), there is also a mapserver container (which mapserver have started to move their demo to)
To access via ssh you should go thru download.osgeo.org -> old-adhoc.lxd It is accessible via https://adhoc.osgeo.org and http://adhoc.osgeo.osuosl.org
osgeo4
osgeo4 is a real server managed by OSUOSL - can be access via ssh tech_dev@osgeo4.osgeo.osuosl.org -p 2222 (only people with their access keys installed can log in and doesn't allow password access) - password for tech_dev is in the secure container (on osgeo7) / access folder.
In August 2019 the server had new power supply put in and replacement disks. It was reformatted with Ubuntu 18.04.3 to serve as secondary LXD host to osgeo7 zfsutils-linux was installed so lxd can use zfs for storage.
sshing into osgeo4 containers
Note that all the containers are closed off from direct ssh access except for the hop.osgeo4.osgeo.org. To access the other containers, you need to hop through hop. hop container has port 22 open but requires ssh access so users who’ve been granted rights can hop thru it to other containers using hop.osgeo4.osgeo.org as name.
A convenient block to add to your own .ssh/config file follows where your_id could be your osgeo id or a local account on that container
Host osgeo4-*
  ProxyCommand ssh your_osgeo_id@hop.osgeo4.osgeo.org -W $(sed -e "s/^osgeo4-//;s/$/.lxd/" <<< "%h"):%p
  User your_id
Then to access say the wordpress-dev container, you'd do the below
ssh osgeo4-wordpress-dev
osgeo4 baremetal features
It's makeup is as follows:
Item Settings
Disks 6 1.8 TB drives
Memory 48 GB
CPUs 8 Intel(R) Xeon(R) CPU E5540 @ 2.53GHz (8192kb cache)
lsblk -i
NAME           MAJ:MIN RM  SIZE RO TYPE  MOUNTPOINT
sda              8:0    0  1.8T  0 disk
|-sda1           8:1    0  953M  0 part
| `-md0          9:0    0  952M  0 raid1 /boot
`-sda2           8:2    0 46.6G  0 part
  `-md1          9:1    0 46.5G  0 raid1
	|-lvm-root 253:0    0 37.3G  0 lvm   /
	`-lvm-swap 253:1    0  7.5G  0 lvm   [SWAP]
sdb              8:16   0  1.8T  0 disk
|-sdb1           8:17   0  953M  0 part
`-sdb2           8:18   0 46.6G  0 part
sdc              8:32   0  1.8T  0 disk
sdd              8:48   0  1.8T  0 disk
sde              8:64   0  1.8T  0 disk
sdf              8:80   0  1.8T  0 disk
sdc,sdd,sde,sdf  form a zfs osgeo4_lxd partition (sdc,sdd) mirrors sde,sdf for total lxd capacity of 3.62 TB
Nightly backups of osgeo7, and osgeo4 containers are kept here and named <container>-backup and be kept in a stopped state.
Cloud Hosted Servers and other external under SAC Control
Future Hosting Plans for Windows / Mac Building
SAC Shared Building Services
Atlantic.net
  • host.postgis.net -p 2222 is an LXD Ubuntu 18.04 16GB RAM/ 6 vCPU, 350GB data, 250GB block storage
  • Currenlty running two lxd containers:
   debbie: debian 10 postgis.net, planet.postgis.net, debbie.postgis.net (jenkins build bot)
   debbie-docker.host.postgis.net - runs docker and serves as a 1.0 agent for dronie.osgeo.org
QGIS off OSGeo
Services on separated machines rented and managed by the QGIS project at hetzner
  • website including documentation http://www.qgis.org
  • website building, documentation building, debian/ubuntu nightlies, plugins.qgis.org
  • issues.qgis.org: redmine
Historical servers (not more in use)
- Telascience Blades (Historical)
web18a.osgeo.osuosl.org
NO LONGER USED - turned off 2019-09-03 Production services www.osgeo.org, 2018.foss4g.org moved to wordpress container on osgeo7 Staging services (staging.www.osgeo.org, dev.www.osgeo.org move to wordpress-dev container on osgeo4 Grass wordpress is disabled as grass decided to go with another solution, so have grass container on osgeo7 (Cloud hosted server on OSUOSL hardware (not ours) )
  • Debian 9.3 4GB server, host name: web18a.osgeo.osuosl.org require ssh key to log in.
  • Hosts wordpress sites staging.www.osgeo.org,www.osgeo.org, staging.grass.osgeo.org, foss4g2018.osgeo.org
  • Setup details on Web18a setup
OSGeo funtoo
For lxd experimentation it's an lxd container running other lxd containers and provided by funtoo.org.
OSGeo is paying funtoo via treasurer at osgeo.org.
  • funtoo LXDs currently running:
    • LimeSurvey -this may be in future migrated to osgeo7 or osgeo3
Migrated to osgeo3 2020-11-28 -- see [[2]]
osgeo3
osgeo3 physical server refer to Configuration Details for hardware specs. It was used to run production, but moderately risky things. Refer to SAC:Old-osgeo3 for past history before osgeo3 was rebuilt. osgeo3 was a hosted by OSUOSL - No longer accessible can be accessed via ssh tech_dev@osgeo3.osgeo.osuosl.org -p 2222 (only people with their access keys installed can log in and doesn't allow password access) - password for tech_dev is in the secure container (on osgeo7) / access folder.
Backup (osgeo5)
  • Backup now runs on dedicated hardware
  • Provides Rsync backups of download.osgeo.org
  • Provides Bacula backups of various VMs.
  • See SAC:Backups for details.
