SAC Meeting 2019-03
From OSGeo
Where and When
Meetings Happened
Thursday Mar 14th 2019 20 UTC Transcript
Agenda
  • OSGeo7 - bacula setup, planning to start this this weekend
  • OSGeo7 - next steps download.osgeo.org move - should we rsync the old first or have OUOSL do it after we've moved (note I have new container setup and put bottle.download.osgeo.org on it. I set on a non-standard ssh port. Will this work for everyone or should we use 22.
  • OSGeo7 issue with seeing real ip - 2 ways to go - upgrade to LXD 3.4 or fiddle with IP tables. I haven't had much luck with IP tables
Talk about hardware plans
    • Regina completed install of nginx lxd container, and nextcloud.osgeo.org (which proxies thru the nginx container), set up a debian9 lxd container for ssh access but shut it down until we decide what to do with it.
    • docker template container completed and used to build dronie server / agent
  • Discovered nginx the way currently set up can't see external ip - need to do differently than just proxying port which means we'll need a dedicated IP for nginx *UPDATE* supposedly LXD 3.0 does support nginx proxy pass ip feature, so might be fine the way it is and just need to tweak some settings
    • Can we ask OSUOSL for an extra ip
NEXT STEPS: For robe - setup container downloads.osgeo.org (will be based off of the debian9 ssh image) (for testing first with no data) and with nginx will require LDAP ssh
Budget
  • OSUOSL donation and FunToo donation are we set?
    • FunToo submitted to monthly payment plan, did treasurer figure it out?
    • OSUOSL, need to submit request to treasurer.
System Contracts
  • Regina has a draft contract would like to go over - added ticket numbers and slated things for contract
    • Contract forwarded to OSGeo for signatures.
  • New contract for Vicky for supporting Wordpress www.osgeo.org,
    • TODO: Draft contract and discuss
  • LDAP+SSH Keys
  • Migrating OSGeo Wiki Logins to OSGeo LDAP
Open tickets needing attention
  • 2019.foss4g.org needs oauth with github - 22228 wildintellect should close if no further feedback from requester [CLOSED]
  • https://trac.osgeo.org/osgeo/ticket/2190 (Vicky has in progress, needs feedback) [DONE still need feedback? ] - Assume DONE DONE
    • maybe we could also setup a domain like elections.osgeo.org too
    • important that only CRO has access to elections stuff
  • #2199 Upload FOSS4G PDF Waiting for feedback from Studio 17 -CLOSED because of lack of response
  • [https://trac.osgeo.org/osgeo/ticket/2195 Blog account for Astride - this should be on www.osgeo.org? Asked for clarification - CLOSED because of lack of response
  • Domain Renewals (needs ticket)
Other topics
  • are we feeling ok now with the cracked geotools account on osgeo6?
  • We need to change the passwords, and move to key only login
  • confirmed password auth is now off
  • we should clean the keys and deploy new ones
  • geotools should create new keys and supply the public key.
SAC main page
