Integrating a module to 3d scan a house within the MapMint4ME android application
From OSGeo
Introduction
Introduction of MapMint
MapMint4ME is an Android application to record your data on the field. MapMint4ME is an Android application for MapMint web-mapping services. MapMint4ME gives the users capability to store data without using the internet locally. The data can be a file stored in alpha-numeric format, an audio file, a video file or readings obtained from a Sensor Observation Service (SOS). When the user returns back to a place with network connectivity, the recorded data can be uploaded back to the server.
MapMint4ME is an android application for MapMint web-service. MapMint is an internet-based Geographic Information System(GIS), designed to facilitate the deployment of Spatial Data Infrastructure(SDI). In an SDI, geographic data, metadata, tools, and the users are connected in an interactive manner in a framework so as to use the spatial information in an efficient and flexible way.
Project proposal
My proposal for GSoC 2021.
Abstract
This project allows a minimalist 3D scan (taking multiple pictures, recording camera position, using opendrone map to rebuild the 3D scene) with the house faces (accessible/visible faces) then load it as georeferenced data and finally export the data back on MapMint for 3D viewing.
Link to Github repository
Timeline
17th May - 7th June (Community bonding period)
Week One: 7th - 13th June
  • What have I done this week:
    • Gone through some of the code of the app with mentor
    • Solved the soft link problem in Windows
    • Added a button for 3D scene in the home page
    • Started the layout for the 3D scene page
    • Gone through some documentation regarding javascript in WebView in Android
  • Am I blocked on anything:
    • How to make the binding between javascript and java
    • How the whole app is working, and how everything is linked to everything
  • My plans for next week:
    • Working harder on my blockings
    • Begin implementing the pictures taking within the app
Week Two: 14th - 20th June
    • Worked on UI elements on the android app
    • Discussed with mentor some issues of the SQL queries in the newly set up online MapMint live instance
    • I am not blocked on anything.
    • Debug online MapMint instance
    • Collect images from phone, experiment with creating a form
Week Three: 21th - 27th June
    • Connect the android MapMint4ME app to MapMint.
Week Four: 28th June - 4th July
    • Make zoo-service to get data from odm
Week Five: 5th - 11th July
    • Continue working on getting the zoo service up and running
Week Six: 12th - 18th July
    • Had a meeting with mentor, which was highly productive, and resulted in the other accomplishments of this week.
    • Removed a symbolic link to make sure the service will be running well see in my GitHub wiki
    • Added a template that will be generated by the service code here
    • Tried getting the template working
Week Seven: 19th - 25th July
    • Added a volume to the zoo-kernel container to get access to the templates
    • Added a volume to the zoo-kernel container to get access to 3D models
    • Visualized a 3D model (.gltf) whitin cesium
Week Eight: 26th July - 1st August
    • - Switched from Cesium to threeJS as viewer of the 3D data
    • Added odm 3D results to 3dModels volume
    • Created a simple user interface to view the 3D model
    • Working on creating a drop list using cheetah template to allow the user to choose what model (from the existing ones) to view
    • Continue working on UI
Week Nine: 2nd - 8th August
    • Finished the final draft for my UI (to render 3D models)
    • Created a drop list to allow the user to choose what model (from the existing ones) to view
    • Loaded successfully multiple sample models (**Tajjin** / **Rock** / **GerrardHall_Building**) all processed by me usig odm . [See here.]
    • Refactor & clean up the code for loading the 3D models
Week Ten: 9th - 15th August
    • Fixed the apt-key issue
    • Clean up the code used to view the 3D models
    • Working on documenting the numerous parts of my project
GSoC 2021 Final Report
Abstract:
This project allows a minimalist 3D scan (taking multiple pictures, recording camera position, using opendrone map to rebuild the 3D scene) with the house faces (accessible/visible faces) then load it as 3D model and export the data back on MapMint for 3D viewing.
The state of the art BEFORE GSoC:
Have you ever wished that you could easily transfer a real object into a digital file? The technology is here, but most of us simply do not have access to high-end 3D scanners that can reconstruct the digital geometry of a physical model.
The added value:
Now it is possible to take multiple pictures using MapMint4ME, then visualize the 3D model issued from the taken pictures in MapMint.
Future Work:
  • One challenging part of my project, not yet done, is to get to link the MapMint4ME with a MapMint instance.
  • I did not get enough time to automate the step of creating the model using openDroneMap, here is what i was thinking to do.
Permanent links & documentation:
Code Repositories:
Videos:
Other Important Links:
Documentation
My work consist of three parts:
  • One graphical image describing my project:
Caption text
Part One: Get the pictures using MapMint4ME
Here are the commits for this part.
  • Created a button that direct you to the this layout.
  • I have created a form that can be filled with a fixed number of images taken from the mobile MapMint4ME app, and will be transfered to MapMint, here is how to do it.
  • I have some issues regarding linking MapMint to MapMint4ME, so I did get the datasets for buildings from here, and I have taken the tajjin pictures by myself.
Part Two: Create the 3D model using ODM
  • I have created a 3D model from pictures, here is the tutorial.
Part Three: Visualize the 3D model in MapMint
  • Got MapMint working on virtual machine tutorial here, then I finished up with configuring it on Docker tutorial here.
  • Added 3D models to the volume see here.
  • Used docker volumes to get access to the 3D models to be visualized.
  • Using threeJS, I was able to render the 3D models in MapMint, using a template.
Mentors
