MapServer at AdhocVM
From OSGeo
this page is OUTDATED: see instead: https://wiki.osgeo.org/wiki/MapServer_at_osgeo7
Startpage
Server Overview
Status
  • 2021-11-07
    • @Robe pointed demo.mapserver.org to new osgeo7 'mapserver' VM, and this old-adhoc VM to old.demo.mapserver.org
  • 2021-05-16
    • jmckenna restarted Apache (machine was rebooted and Apache not started)
  • 2021-01-01
  • 2020-10-27
  • 2020-04-20
  • 2020-04-05
    • jmckenna
      • upgraded cmake to 3.9.6
      • upgraded to MapServer 7.4.4
  • 2020-03-21
  • 2020-03-14
    • jmckenna
      • updated tutorial for MapServer 7.4.3
      • upgraded OpenSSL to 1.1.1d, and rebuilt mapserv 7.4.3 with KML output
  • 2020-02-29
    • jmckenna restarted Apache services
      • upgraded mapserv to 7.4.3
      • updated /osgeo/mapserver/msautotest/world/world.map for MapServer 7+
  • 2019-11-21 built mapserv74 CGI for demo.mapserver.org
  • 2019-05-12 demo.mapserver.org/geocache not accessible (this serves the OSM tiles on the mapserver.org homepage), as old machine shut down.
    • jmckenna restarted its Apache service
    • robe proxied to 8081/geocache
  • 2019-05-11 demo.mapserver.org not accessible, as old machine shut down.
    • robe opened the domain through nginx
    • jmckenna restarted FGS Apache service
  • 2014-05-28 changed postgres port from 5432 to 5433
  • 2010-09-28 mapserver tutorial configured
  • 2010-09-23 mapserver installed through FGS
Participants
MapServer Installation on AdhocVM
  • MapServer 7.4 statically compiled
  • MapServer 5.6.5 through FGS
  • *home: /osgeo/mapserver/fgs/
Apache Configuration
A virtualhost is setup for demo.mapserver.org, through:
  • /etc/apache2/sites_available/demo.mapserver.org
    • to enable the virtualhost, the following command was used:
   /usr/sbin/a2ensite demo.mapserver.org
Note that a proxy is setup to point to the FGS Apache which is running on port 8080
  • server logfiles live at:
   ErrorLog /var/log/apache2/demo.mapserver.org-error_log
   CustomLog /var/log/apache2/demo.mapserver.org-access_log combined
  • mapserv and other CGI binaries are in the FGS environment: /osgeo/mapserver/fgs/www.cgi-bin
Restarting FGS Apache
  • set the FGS environment, in /osgeo/mapserver/fgs/ execute the command:
   . setenv.sh
  • then execute:
   fgs stop ; fgs start
(if you get 'pg_ctl' errors, verify proper ownership of the folder: /osgeo/mapserver/fgs/apps/pgsql/ )
Adding Apache Aliases
  • see examples in /osgeo/mapserver/fgs/www/conf.d/
Services on the AdhocVM
For each service you configure on demo.mapserver.org, please edit /osgeo/mapserver/fgs/www/htdocs/index.html and list your new service.
MapServer Tutorial (7.4.3)
World Blue Marble
WMS Service (for Documentation)
  • Small mapfile serving a raster file, and a single point, line, and poly file. Used in the MapServer docs.
  • On Disk: /osgeo/mapserver/ogc-demos/map/wms.map
  • On Web: https://demo.mapserver.org/cgi-bin/wms?
  • Administrator: jmckenna
WMS Landsat7 Service (for Documentation)
WFS Service (for Documentation)
  • Small mapfile serving a point and polygon shapefile. Used in the MapServer docs.
  • On Disk: /osgeo/mapserver/ogc-demos/map/wfs.map
  • On Web: https://demo.mapserver.org/cgi-bin/wfs?
WCS Service (for Documentation)
  • Minnesota DNR demo, includes MODIS and NDVI imagery. Used in the MapServer docs.
  • On Disk: /osgeo/mapserver/ogc-demos/map/wcs.map
  • On Web: https://demo.mapserver.org/cgi-bin/wcs?
OGR Examples (for Documentation)
WMS OpenStreetMap Service (for Documentation)
  • OSM data for Colorado loaded into PostgreSQL database, served by MapServer. Used in the MapServer OpenLayers app on main site.
  • On Disk: /osgeo/mapserver/osm/map/osm.map
  • Port: 5433
  • On Web: https://demo.mapserver.org/cgi-bin/foss4g?
  • mapfile styling comes from the 'mapserver-utils' project
    • 'default.style' was used because there were errors with 'mapserver.style'
  • To log into the 'osm' database:
    • cd /osgeo/mapserver/fgs
    • . setenv.sh
    • psql -U postgres -d osm -p 5433
      • password for postgres user is postgres
Caching for mapserver.org OpenLayers viewer
  • geocache.xml lives in:
   /osgeo/mapserver/mapcache/
   sudo /osgeo/mapserver/httpd/bin/apachectl restart
  • mapfile:
  • seed command:
   sudo geocache_seed -c geocache.xml -t osm-denver -g osmgrid -z 0,13
  • cache directory:
   /osgeo/mapserver/mapcache/disk-cache
HTML Legend Examples (for Documentation)
MapServer 7.x CGI
7.6-dev
  • A statically compiled "mapserv76" CGI has been compiled to support the V7+ tutorial. This is a static build so it has no external dependency.
  • Web URL: https://demo.mapserver.org/cgi-bin/mapserv76
  • Source build in /osgeo/mapserver/mapserver-git-branch-7-6/build
  • Administrators: jmckenna
  • build instructions for reference:
$ cd /osgeo/mapserver/
$ git clone -b branch-7-6 https://github.com/mapserver/mapserver.git mapserver-git-branch-7-6
$ cd mapserver-git-branch-7-6
$ mkdir build
$ cd build
$ cmake .. -DWITH_CLIENT_WMS=1 -DWITH_CLIENT_WFS=1 -DWITH_SOS=1 -DWITH_WCS=1 -DWITH_WMS=1 -DWITH_WFS=1 -DWITH_FCGI=0 -DWITH_PROJ=1 -DWITH_GDAL=1 -DWITH_OGR=1 -DUSE_POINT_Z_M=1 -DWITH_PIXMAN=0 -DLINK_STATIC_LIBMAPSERVER=1 -DWITH_PYTHON=0 -DWITH_FRIBIDI=0 -DWITH_HARFBUZZ=0 -DWITH_CAIRO=0 -DWITH_FCGI=0 -DWITH_PROTOBUFC=0 -DWITH_KML=1
$ make
$ cp /osgeo/mapserver/mapserver-git-branch-7-6/build/mapserv /osgeo/mapserver/fgs/www/cgi-bin/mapserv76
7.4.4
  • A statically compiled "mapserv74" CGI has been compiled to support the V7+ tutorial. This is a static build so it has no external dependency.
  • Web URL: https://demo.mapserver.org/cgi-bin/mapserv74
  • Source build in /osgeo/mapserver/mapserver-git-branch-7-4/build
$ git clone -b branch-7-4 https://github.com/mapserver/mapserver.git mapserver-git-branch-7-4
$ cd mapserver-git-branch-7-4
$ mkdir build
$ cd build
$ make
$ cp /osgeo/mapserver/mapserver-git-branch-7-4/build/mapserv /osgeo/mapserver/fgs/www/cgi-bin/mapserv74
7.0.6
  • A statically compiled "mapserv70" CGI has been compiled to support the V7+ tutorial. This is a static build so it has no external dependency.
  • Web URL: https://demo.mapserver.org/cgi-bin/mapserv70
  • Source build in /osgeo/mapserver/mapserver-git-branch-7-0/build
  • Note that this binary has to be installed under the FGS server's /osgeo/mapserver/fgs/www/cgi-bin/ directory since that's where the https://demo.mapserver.org/cgi-bin/ points to
  • Administrators: dmorissette / jmckenna
$ git clone https://github.com/mapserver/mapserver.git mapserver-git
$ cd mapserver-git/
$ git checkout branch-7-0
$ mkdir build
$ cd build
$ cmake .. -DLINK_STATIC_LIBMAPSERVER=1 -DWITH_PYTHON=0 -DWITH_FRIBIDI=0 -DWITH_HARFBUZZ=0 -DWITH_CAIRO=0 -DWITH_FCGI=0
$ make
$ cp /osgeo/mapserver/mapserver-git-branch-7-0/build/mapserv /osgeo/mapserver/fgs/www/cgi-bin/mapserv70
