SAC Meeting 2019-01
From OSGeo
Jump to: navigation, search
Where and When
Meetings Happened
2019-01-03
Agenda
Talk about hardware plans
  • 2205 Regina completed install of Ubuntu 18.04.1 on OSGeo7 on Samsung drive and also installed zfsutils-linux and lxd.
   Regina completed install of nginx lxd container, and nextcloud.osgeo.org (which proxies thru the nginx container), started setting up a debian10 lxd container for ssh access (not completed), docker container completed but tried to load a huge docker container (for collabora which didn't work out so ended up doing a collabora container.  In theory docker should work fine with lxd)
   Also set up a collabora container that allows nextcloud.osgeo.org to be able to edit office documents online
NEXT STEPS: For robe - setup container downloads.osgeo.org (for testing first with no data) and with nginx will require LDAP ssh (requires figuring out theldap/ ssh issue on lxd)
  • DONE: To do people should start testing nextcloud
  • FTP mirror on OSUOSL hardware, do we want an to push or pull with rsync or other method. TODO: make sure there's a ticket.
Budget
  • We need to make a 2019 Budget to submit to the board. 2019 Proposal
  • 2018 - How much did we actually spend?
    • Only 1 contract partly used
    • OSUOSL donation never happened because board wanted to add more $ but never voted on it?
System Contracts
  • Martin's contract is half used, hope he can continue, but might require extension of period of service.
  • New contracts both Vicky and I would like to have contracts - Vicky for supporting Wordpress www.osgeo.org, I for supporting new lxd system and setting up new apps on it
Open tickets needing attention
Other topics
  • are we feeling ok now with the cracked geotools account on osgeo6?
  • We need to change the passwords, and move to key only login
  • confirmed password auth is now off
  • we should clean the keys and deploy new ones
  • geotools should create new keys and supply the public key.
SAC main page
