Building Mapguide on Ubuntu 6.06 Server
From OSGeo
Installing Mapguide Open Source on Ubuntu Server 6.06
This was done with a lot of help from the Autodesk team (thanks!)
Basic Setup
Install a basic Ubuntu Server 6.06 (the rest of this guide assumes no GUI and that you are not running as the root user)
Using apt, install the following:
subversion, gcc, g++, flex, bison, automake 1.9, libjpeg62, libjpeg62-dev, libtool, zlib1g, zlib1g-dev, libxml2-dev, make, build-essential
wget http://svn.osgeo.org/fdocore/branches/3.2.x/checkoutsvn.sh
edit checkoutsvn.sh with the following:
FDO_SVN_USERNAME=guest
FDO_SVN_PASSWORD=guest
FDO_SVN_SOURCEDIR=branches/3.2.x
mkdir fdosvn
cd fdosvn
/path/to/checkoutsvn.sh
permanently accept the certificates and then cancel the script (ctrl+c for each checkout)
find .subversion/config (hidden directory probably in your home directory)
edit config with the following (either by commenting out or adding):
in the [miscellany] section:
use-commit-times=yes
enable-auto-props=yes
in the [auto-props] section:
*.* = svn:eol-style=native
*.sh = svn:executable
rm -rf fdosvn/*
rm -rf fdosvn/.svn
checkoutsvn.sh
cd /usr/local
sudo mkdir fdo-3.2.0
sudo mkdir fdo-3.2.2
sudo chown (your user) fdo-3.2.0
sudo chown (your user) fdo-3.2.2
cd ~/fdosvn
source ./setenvironment.sh
nohup ./build_thirdparty.sh >& buildthirdparty.log (if you want to log the build)
nohup ./build_linux.sh >& buildlinux.log
Apache/Php
cd
mkdir mgdev
svn co http://svn.osgeo.org/mapguide/branches/1.2.x/
install using apt:
libcurl3, libcurl3-dev, libxslt1.1,libxslt1-dev, expat
sudo mkdir /usr/local/mapguideopensource
sudo chown (your user) /usr/local/mapguideopensource
edit /etc/apt/sources.list to include the multiverse
install using apt:
sun-java5-jdk (accept the license)
export JAVA_HOME=/usr/lib/jvm/java-1.5.0-sun-1.5.0.06 (or similar)
cd /your/home/directory/mgdev/Oem/LinuxApt
extract all the tar.gz files
./build_apt.sh
Build_oem
Install using apt:
automake1.7 (but don't change symlinks or anything)
./build_oem.sh
If you receive an error relating to CppUnit then do the following:
pushd Oem/CppUnit-1.9.14
rm aclocal.m4
popd
./build_oem.sh
Build Mapguide
Install using apt:
libexpat1, libexpat1-dev, doxygen
sudo chown (your user) /usr/lib/python2.4
aclocal
libtoolize –-force
automake –-add-missing –-copy
autoconf
./configure –-enable-optimized
make
make install
Problems?
Can't find webstudio?
cp -R /your/home/directory/mgdev/Web/Src/webstudio /usr/local/mapguideopensource/webserverextensions/www/webstudio
