Mapbender at AdhocVM
Startpage
Server Overview
Status
- 2010-08-08 configuration is done, mapbender 2.6.2 available
Participants
- User:Astrid Emde (astrid_emde@osgeo.org)
- kmq
- banjo
- Admins see http://www.mapbender.org/Category:Administrators
additional Software on AdhocVM
- Mapbender
- PostgreSQL/PostGIS
- svn
- gettext
Services on the AdhocVM
- every Mapbender version is presented on this server http://adhocvm.mapbender.osgeo.org/
- if you need root access to the demo mapbender ask the participants (see above)
- the home for the Mapbender packages is: /osgeo/mapbender/
- the update of the mapbender version is done by svn
- we offer a portal function so user can login and try the applications
- as adminstrative database we use PostgreSQl/PostGIS
Apache
- /etc/apache2/sites_available/adhocvm.mapbender.osgeo.conf
- logfiles at:
ErrorLog /var/log/apache2/adhocvm.mapbender.osgeo.org-error_log CustomLog /var/log/apache2/adhocvm.mapbender.osgeo.org-access_log combined
How to setup the current mapbender version
Mapbender Database
- use the install.sh
- take the last version as template (check the guis first - everything still allright?)
- (postgis_template)
directory and svn checkout
cd /osgeo/mapbender sudo bash mkdir mapbender_2.6 svn co https://svn.osgeo.org/mapbender/branches/2.6 /osgeo/mapbender/mapbender_2.6/ cd /osgeo/mapbender/mapbender_2.6/resources/db/ chmod u+x install_2.6.sh ./install_2.6.sh --> use template_postgis as database template
for update use:
svn up https://svn.osgeo.org/mapbender/branches/2.6 /osgeo/mapbender/mapbender_2.6/ cd /osgeo/mapbender/mapbender_2.6/resources/db/ chmod u+x update.sh ./update.sh
Change the root password
- the root password has to be changed to the password the devs defined (ask administrators)
