OSGeo-Knowledge-Embedding-Server
BGE-M3 embedding server for semantic search, running on Gallery_Container.
It provides local embeddings for Osgeo-library and other OSGeo AI/search tooling.
Model
Verified model file on osgeo7-gallery:
/home/ominiverdi/models/bge-m3-Q8_0.gguf
Model details:
- Model family: BGE-M3
- Upstream: BAAI
- Quantization: Q8_0
- File size: 606 MB
- Vector size: 1024 dimensions
- Multilingual: supports 100+ languages
Endpoint
The service listens on localhost only:
http://localhost:8094/embedding
Configured by Osgeo-library in:
/home/ominiverdi/github/osgeo-library/config.toml /home/ominiverdi/github/osgeo-library/config.example.toml
Runtime
The service runs through llama.cpp / llama-server.
Startup script:
/home/ominiverdi/github/osgeo-library/servers/bge-m3-cpu.sh
The script uses:
/home/ominiverdi/llama.cpp/build/bin/llama-server /home/ominiverdi/models/bge-m3-Q8_0.gguf
It binds to:
127.0.0.1:8094
Automatic startup
The service is started at reboot from the ominiverdi crontab:
@reboot cd ~/github/osgeo-library && nohup ./servers/bge-m3-cpu.sh >> ~/logs/bge-m3-cpu.log 2>&1 </dev/null
Related API startup entry:
@reboot ~/github/osgeo-library/servers/start-server.sh >> ~/logs/osgeo-library.log 2>&1
Operations
Check listener status:
ss -ltnp | grep 8094
Expected listener:
127.0.0.1:8094
Check process status:
pgrep -af "llama-server.*8094|bge-m3"
Check health:
curl http://127.0.0.1:8094/health
Expected result:
{"status":"ok"}
Check from Osgeo-library:
cd /home/ominiverdi/github/osgeo-library
/home/ominiverdi/github/osgeo-library/.venv/bin/python - <<'PY'
import asyncio
from doclibrary.servers.mcp import get_library_status
async def main():
print(await get_library_status())
asyncio.run(main())
PY
Expected status includes:
Embedding server: OK Database: OK
View logs:
tail -f /home/ominiverdi/logs/bge-m3-cpu.log
Start manually:
cd /home/ominiverdi/github/osgeo-library nohup ./servers/bge-m3-cpu.sh >> ~/logs/bge-m3-cpu.log 2>&1 </dev/null &
Stop manually:
pkill -f "llama-server.*8094"
Consumers
Contact: ominiverdi, Lorenzo Becchi, or SAC channel.
