TorchGeo embeddings
[arXiv:2601.13134v1] [cs.SE] 19 Jan 2026
Earth Embeddings as Products: Taxonomy, Ecosystem, and Standardized Access is a comprehensive survey that organizes existing geospatial embedding products into a structured taxonomy through a three-layer taxonomy: Data, Tools, and Value. This research paper provides a detailed metadata atlas (resolution, license, etc.). It also proposes a unified integration by implementing standardized data loaders for these embeddings in [TorchGeo] .
An overview landscape is proposed comprising: a) Analysis Frameworks & Tools b) Embeddings data artifacts c) Charting downstream application value, specifically mapping tasks and retrieval tasks.
Embeddings are differentiated as either location-typed, patch-typed, or pixel-typed. Details of existing products are shown. "We extend TorchGeo with a unified API that standardizes the loading and querying of diverse embedding products."
1. Foundation Models for Earth Observation (EO)
These are the leading projects that aim to build general-purpose models capable of representing Earth from satellite imagery and other geospatial modalities.
OlmoEarth – [AllenAI] (2025) *: multimodal Latent image modeling ; data: pretrain dataset Major TOM – [MajorTOM] (Terrestrial Observation Metaset) framework & massive satellite dataset ; European Space Agency's Φ-lab. ; data: MMEarth Copernicus-Embed – [LINK] AI4Copernicus Project Foundation model MOSAIKS - [MOSAIKS] Clay Foundation Model – [Clay] (2024) *: multimodal foundation model ; data: source.coop Earth Index Embeddings – [EarthGenome] (2025) *: A large-scale embedding system ▪ Google Satellite Embedding (AlphaEarth) – [LINK] Google Earth Engine *: ▪ Presto Embeddings – [NASAHarvest] *: satellite time series / land use ; data: GEE asset ▪ Tessera Embeddings – [GeoTessera] Docs / [REPO] *: Temporal spectral embeddings ▪ ESD - [ESD] ; data: iEarthData PRC China • Satlas from AI2 - [satlas] • Prithvi-EO-2.0 from NASA/IBM - [Prithvi-EO-2.0-600M] • TerraMind from IBM/ESA - [TerraMind] • SatCLIP from Microsoft - [satclip] • Galileo from NASA - [galileo] (pixel-capable)
▪ Pixel-level
• Weights only
Research Papers
- XXZhu 2025 [LINK] "On the Foundations of Earth Foundation Models" – Nature Computational Science
- CFBrown 2025 [LINK] "AlphaEarth Foundations"
- KKlemmer 2023 [LINK] "SatCLIP: Global Location Embeddings with Satellite Imagery"
- Bollinger [MOSAIKS] A generalizable and accessible approach to machine learning with global satellite imagery
2. Datasets
Large-scale, open-access datasets play a central role in training and evaluating Earth foundation models. See the table below for a representative sample. dataset table LINK
3. Model Architectures for Embeddings
The generation of robust Earth observation embeddings relies on specific model families pre-trained on large-scale geospatial data. The following architectures are central to the TorchGeo ecosystem and recent foundation model research, categorized by their primary learning paradigm.
Vision-Language Models
These models align visual satellite imagery with textual or geographic metadata, creating unified embedding spaces for cross-modal retrieval.
- SatCLIP – [[LINK]] (AAAI 2025)
A vision-language model designed to generate global location representations by aligning satellite imagery with geographic text embeddings, originally published in 2023 and widely studied.
A global dataset for multi-modal and geospatial representation learning. It consists of 12 modalities including pixel-level and image-level modalities from 1.2 million locations.
Self-Supervised Vision Transformers
Transformers pre-trained via self-supervised objectives (e.g., DINO, MAE) are currently the state-of-the-art for extracting rich, transferable embeddings from remote sensing imagery.
- DINO / DINOv2 / DINOv3 – [[LINK]] (Meta/INRIA, 2021–2023)
Vision transformers trained with self-distillation without labels. DINOv2, in particular, produces highly discriminative embeddings that capture fine-grained geospatial features without downstream fine-tuning.
- MAE (Masked Autoencoders) – [[LINK]] (CVPR 2021)
A self-supervised encoder that learns robust image representations by reconstructing masked patches. When applied to satellite data, MAE embeddings capture global context and local texture effectively.
Efficient Convolutional Backbones
While Transformers dominate embedding research, optimized CNNs remain critical for efficient embedding extraction in resource-constrained environments or as feature extractors for hybrid models.
- ConvNeXt V2 – [[LINK]] (Woo et al., CVPR 2023)
A modernized ConvNet that incorporates Transformer-like design principles (e.g., large kernel sizes, layer normalization). It serves as a high-performance, efficient backbone for generating spatial embeddings in TorchGeo.
- ResNet – [[LINK]] (He et al., CVPR 2016)
The foundational residual network. While older, ResNet variants remain the standard baseline for comparing embedding quality in early-stage Earth Foundation Model development.
Distillation & Advanced Approaches
- Distillation methods – Transfer knowledge from large models.
- Neural plasticity-inspired models – TorchGeo_DOFA: Inspired by biological learning mechanisms.
- Multi-label guided soft contrastive learning – YWang, IEEE TGRS, 2024.
- Barlow Twins – Method for learning representations without contrastive loss.
- Continual Barlow Twins – Extends Barlow Twins to continual learning in EO segmentation.
4. Tools & Benchmarks
These are software systems and frameworks that support development, evaluation, or deployment of EO AI models.
Tools
- TorchGeo – [TorchGeo] [ACM] AJStewart et.al. PyTorch library for geospatial deep learning.
- NeuCo-Bench – [LINK] RVinge, arXiv 2025 Benchmarking framework for neural embeddings in Earth observation.
- GeoINRID – [LINK] GitHub: arjunarao619/GeoINRID Geospatial inference and representation learning toolkit.
- GEO-Bench-2 [geoBench] (19 tasks, many GeoFMs)
- PANGAEA [pangaea-bench]
- torchgeo/geo-eval-harness [geo-eval]
Challenges
- Embed2Scale Challenge – [LINK] CVPR CAlbrecht 2025
Large-scale Earth vision challenge focused on scale-aware embeddings.
- TerraMind Blue-Sky Challenge –
Generative modeling for Earth observation.
5. Themes (under construction)
- Foundation Models: TorchGeo now includes data loaders designed for search/retrieval (Clay, Major TOM, Earth Index), and for dense prediction tasks like land cover mapping (Copernicus, Presto, Tessera, Google). TorchGeo allows us to enable fair, side-by-side benchmarking of different embedding models on the same downstream tasks, forming the basis for future experiments. Projects are encouraged to strengthen and improve explainability.
- Major TOM Notes: Major TOM embeddings are not (yet) really product-oriented and are aimed with a similar purpose to the MT Core datasets - to make it easier to experiment and benchmark model outputs (hence, unlike TESSERA and AEF which came a few months after, MT embeddings do not have consistent or aggregated temporal scope). We haven't had enough time to finish off the preprint, but my current plan is to provide a simple MT Embedding benchmark at this year's EGU and integrate that into the arxiv pre-print. --Miko
- Earth Index / Earth Genome: Use the Earth Index application (earthindex.ai) for non-technical users to use the embeddings we published on source.coop. Users of the web app (non-technical journalists, indigenous communities/allies, NGOs) have been our main focus. Users of the source.coop embeddings have generally been more technical folks interested in exploring/innovating in what's possible --BenStrong
- Clay: Clay and Presto offer documented tutorials on generating new embeddings with their models. In CLAY, the encoder receives unmasked patches, latitude-longitude data, and timestep information. Notably, the last 2 embeddings from the encoder specifically represent the latitude-longitude and timestep embeddings.
- Self-Supervised Learning (SSL):
- Multimodal Integration:
- Open Data & Tools: Open-source projects (e.g., TorchGeo, Copernicus-Embed) and public datasets (EuroSAT, EuroCrops) are crucial for reproducibility and democratization of EO AI. Projects are encouraged to increase Input Data Diversity, and to adopt cloud-native data formats for geospatial data.
- Benchmarking: Benchmarks including NeuCo-Bench / Embed2Scale LINK ; ServiceNow Geo-Bench LINK , PANGAEA LINK PDF ; TorchGeo geo-eval-harness LINK ; ESA PhilEO Bench LINK
Datasets Misc
| Dataset | Description |
| EuroSAT – [Zenodo] | Land use classification dataset using Sentinel-2 satellite data. |
| EuroCrops – [PMC_10495462] | Crop type mapping dataset for Europe. |
| National Land Cover Database (NLCD) – [MRLC] | USA land cover classes. |
| SSL4EO-S12 – [GitHub] | Multimodal, multitemporal dataset for self-supervised learning. |
| Copernicus-Pretrain – [GitHub] | An extension of the SSL4EO-S12 dataset to all major Sentinel missions (S1-S5P). |
| BigEarthNet – [BigEarthNet] | Large-scale multi-label satellite image classification dataset. |
| Resisc45 – [IEEE DOI] | Remote sensing image classification dataset with 45 categories. |
| UC Merced – [UC Merced] | Aerial image dataset for land use classification. |
| Potsdam – [ISPRS] | Semantic segmentation dataset for urban areas from aerial imagery. |
| Vaihingen – [ISPRS] | Semantic segmentation dataset for urban areas from aerial imagery. |
| Inria Aerial Image Labeling – [Inria] | Aerial image segmentation dataset for building footprint extraction. |
| NAIP – [USGS EROS] | National Agriculture Imagery Program data for the USA. |
| Sentinel-2 – [Copernicus] | Multispectral imagery from the Sentinel-2 mission. |
| Landsat – [USGS Landsat] | Long-term archive of medium-resolution satellite imagery. |
| OpenStreetMap – [OpenStreetMap] | Collaborative project to create a free editable map of the world. |
| GFED (Global Fire Emissions Database) – [Global Fire Data] | Global dataset of biomass burning emissions. |
| GBIF – [GBIF] | Global biodiversity information facility dataset. |
| Open Buildings – [Microsoft Research] | Global building footprint detection dataset. |
| OpenAerialMap – [OpenAerialMap] | Open-source aerial imagery dataset. |
| Major-Tom – [GitHub] | Large-scale remote sensing image classification dataset. |
| Google Satellite Embedding – [Google Earth Engine] | Pre-trained embeddings for Google satellite imagery. |
| Dota – [DOTA Website] | Large-scale dataset for object detection in aerial images. |
Research Directions
- Unified Earth Foundation Models:
- Interpretability in EO AI: Exploring how these embeddings can be interpreted by domain experts.
- Ethics and Bias: Investigating fairness and bias in global EO models trained on unevenly distributed data.
- Edge Deployment: Making these large foundation models deployable on resource-constrained platforms (e.g., for field use).
| title = Earth Embeddings as Products: Taxonomy, Ecosystem, and Standardized Access
| authors = Heng Fang< †, Adam J Stewart ‡, Isaac Corley§, Xiao Xiang Zhu *, Hossein Azizpour †
| affiliations =
* † KTH Royal Institute of Technology, Stockholm, Sweden
* ‡ Chair of Data Science in Earth Observation, Technical University of Munich, Munich, Germany
* § Wherobots, San Antonio, USA
| arxiv = 2601.13134v1 (19 Jan 2026)
https://arxiv.org/html/2601.13134v2
Glossary
| Acronym | Meaning | Definition |
| AI | Artificial Intelligence | When a machine (e.g., computer) demonstrates human-like behavior |
| ML | Machine Learning | A subset of artificial intelligence involving learning from example |
| DL | Deep Learning | A subset of machine learning involving the use of deep neural networks |
| FM | Foundation Model | A model pretrained on broad data and applicable to broad applications |
| LLM | Large Language Model | A foundation model designed for natural language processing |
| VLM | Vision–Language Model | A foundation model designed to jointly process image and text data |
| MoE | Mixture of Experts | The use of an ensemble of models, each trained on a subset of local data |
| GPU | Graphics Processing Unit | A specialized computer component designed for digital image processing |
| TPU | Tensor Processing Unit | A specialized computer component designed for matrix multiplication |
| EO | Earth Observation | Gathering information about the Earth via remote or in situ sensors |
| RS | Remote Sensing | Gathering information about an object without making direct contact |
| SAR | Synthetic-Aperture Radar | A form of radar that uses motion to artificially increase spatial resolution |
| RGB | Red-Green-Blue | Traditional camera technologies designed to capture the visible spectrum |
| MS | Multispectral | Captures 3–15 disjoint spectral bands (e.g., infrared, visible, ultraviolet) |
| HS | Hyperspectral | Captures hundreds of contiguous spectral bands, high spectral resolution |
| S2S | Subseasonal to Seasonal | Weather patterns occurring on a time scale of two weeks to two years |
