SAC:staging2.www.osgeo.org
Contents
OBSOLETE
new staging is on osgeo4. Refer to [1]
wwwosgeo (staging server) is running on winnie.postgis.net virtual box ssh port 53022, passwords on secure/access server
Setup from Disk the prompts
- Virtual Box use VMDK, dynamically allocated, 100GB
- Start with debian-9.3.0-amd64-netinst.iso image ( https://cdimage.debian.org/debian-cd/current/amd64/iso-cd/debian-9.3.0-amd64-netinst.iso (2017-12-09)
(Regular install, don't use graphical)
- set mirror to debian.csail.mit.edu
- Participate in Package Usage: Yes
- Uncheck Debian Desktop Environment
- Check SSH server
- Check Web Server
- Uncheck Print Server
- Install Grub
- Select 2nd option (only drive)
Install LDAP SSH support
Note for the remainder of installs, I went with apt instead of (apt-get or aptitude) Per Debian Handbook apt, apt is the preferred installer and what I saw being used for newer Debians.
su root apt install locales-all libpam-ldapd libnss-ldapd apt install sudo apt install tcsh
- During install fill in below and check passwd, group, shadow
apt install ldapscripts
/etc/ldap/ldap.conf should have this
BASE dc=osgeo, dc=org URI ldaps://ldap.osgeo.org/ #SIZELIMIT 12 #TIMELIMIT 15 #DEREF never TLS_CHECKPEER yes TLS_REQCERT demand TLS_CACERT /etc/ssl/certs/ca-certificates.crt #I'm using genric one, osgeo6 is different pam_groupdn cn=telascience,ou=Shell,dc=osgeo,dc=org #not though telascience is defunct so not sure what that cn nss_base_passwd ou=People,dc=osgeo,dc=org nss_base_shadow ou=People,dc=osgeo,dc=org nss_base_group ou=Group,dc=osgeo,dc=org ldap_version 3 pam_password md5 bind_policy soft
- copy contents of /etc/nslcd.conf from osgeo6
- nano /etc/nsswitch.conf
conf should look like
# /etc/nsswitch.conf # # Example configuration of GNU Name Service Switch functionality. # If you have the `glibc-doc-reference' and `info' packages installed, try: # `info libc "Name Service Switch"' for information about this file.
passwd: compat ldap group: compat ldap shadow: compat gshadow: files
hosts: files dns networks: files
protocols: db files ldap services: db files ldap ethers: db files rpc: db files
netgroup: nis aliases: ldap
service nscd restart service nslcd restart service ssh restart
Verify ldap authentication and query all set up
getent passwd robe
- should output:
robe:x:15108:100:Regina Obe:/home/robe:/bin/bash
ldapsearch -x uid=robe
- should output a lot of information about Regina
cp -a /etc/skel /home/robe chown -R robe:100 /home/robe
- add robe to sudoers
sudo usermod -a -G sudo robe sudo usermod -a -G www-data robe
should now be able to log in as robe
Installing PHP, MariaDb etc for wordpress
sudo apt install mariadb-server #installed Mariadb 10.1
- Install apache, php7
sudo apt install apache2 #was already installed as part of setup so not needed
- on debian 9, php7.0 is default, so I can dispense with php7.0 prefix,
- for older, might have to do php7.0, libapache2-mod-php7.0 etc.
sudo apt install php php-dev libapache2-mod-php php-mysql php-curl php-gd php-xmlrpc php-intl php-mcrypt php-xsl sudo apt install php-ldap
Download backups and restore, and setup website
copy configs to etc/apache2/sites-available (for this server I created staging version) copy database and sql backups from old server to /var/www/backups
sudo a2dissite 000-default.conf sudo a2ensite staging.www.osgeo.org.conf sudo a2enmod rewrite sudo a2enmod file_cache sudo a2enmod expires
cd /var/www/backups tar -xvf osgeo_wp_daily.tar.gz mv osgeo.org /var/www/staging.osgeo.org
cd /var/www sudo chown -R www-data:www-data staging.osgeo.org sudo chmod -R 770 staging.osgeo.org
- create new database and user and restore backup
mysql CREATE USER 'osgeo_site' @'localhost' IDENTIFIED BY 'look in config for password';
CREATE DATABASE staging_osgeo; GRANT ALL ON staging_osgeo.* TO 'osgeo_site'@'localhost'; exit
- restore backup
cd /var/www/backups sudo gunzip osgeo_daily.sql.gz sudo mysql --user=root staging_osgeo < osgeo_daily.sql
sudo apt update sudo apt upgrade sudo reboot
- you may need to fiddle with the www/osgeo.org/httpdocs/core/.htaccess if you are setting up a dev
sudo systemctl reload apache2
Install apache, php7, sendmail
Mail config needed for WP-SMTP
sudo vi /etc/hostname #set to full domain in this case staging2.www.osgeo.org
sudo apt install sendmail
download backups and restore
Create new database and user and restore backup
- restore backup
