Telascience Blades (Historical)
Servers at Telascience Blades
HISTORICAL INFORMATION
This only describes some of the osgeo oriented systems and is not a full description of the telascience reality in any way
Telascience Disks
HyperCube
- Full details on HyperCube
- Used primarily for geodata serving.
Lantronix SLC8
deviceports
1 B1600-SC0 << blade consoles 2 B1600-SC1 3 LX50 4 Port-4 5 SE3510 6 Port-6 7 V20z
- ssh sdsu-slc.telascience.org
[SDSU-SLC]> connect direct deviceport 1 Connected to port 1. Escape sequence is ESC A << Important Info username: password: B1600-sc> B1600-sc>console S11 [Connected with input enabled on fru S11] Escape Sequence is '#.' << Important Info
[root@xblade11]#
xblade10-2
- (198.202.74.215) FC4
- STATUS: This system was compromised and is currently shutdown pending reformatting.
- LDAP Shell enabled, yum updated Nov 5th/2006.
mapbender at mapbender.telascience.org (postgres, mysql running)demo.mapserver.org : demo map servers for MapServer project- migrated to ProjectsVMGeoNetwork opensource website http://geonetwork-opensource.org- migrated elsewhere
The Plone service should start automatically. In case it doesn't it can be started manually running /etc/rc.d/init.d/zopectl start
xblade11-2 (buildtest)
- (198.202.74.216) FC4 (DNS: buildtest.osgeo.org)
- LDAP Shell enabled, normal system setup done. March 28, 2008
- This server got a new disk in February because the old one died, so all previous contents are lost.
- Use 87GB /osgeo partition for bulk of work on this system, limited space in /home.
- Assigned as a build and regression testing server for Buildbot slaves, and related systems like Hudson for GeoNetwork and Geotools.
- Hudson does not restart automatically!
- Details on the Hudson Configuration on this system.
- hosts tiles for the mapserver front page demo MapServerTiles
- host foss4g2009 workshop uploads per #407
- host foss4g2010 workshop uploads per #563
xblade12-2 (Kids GIS)
- (198.202.74.217) FC4
- new server: new install, no ldap or remotely mounted home.
- This machine is allocated to Kids GIS Portal
xblade13-2 (download)
- (198.202.74.218) FC4
Decommissioned
xblade14-2 (buildbot | upload | GeoTools | Gallery | FOSS4G2007)
- (198.202.74.219) FC4
- STATUS: This system was compromised and is dead. Servers migrated to ProjectsVM
- only gallery.osgeo.org is on WebExtraVM
- LDAP Shell enabled, yum updated July 19th/2006.
- buildbot.osgeo.org: OSGeo BuildBot Configuration.
- Using for Community Mapbuilder Continuum Builds.
- MapServer
- script preparing nightly svn snapshots (/osgeo/mapserver - cronjob under frankw)
- mapserver.org: /osgeo/mapserver/mapserver-web, including scripts to recreate things using Sphinx (hobu/jmckenna)
- GRASS (http://grass.osgeo.org/) (migrated to projects.osgeo.osuosl.org)
- /osgeo/grass/grass-web is the svn checkout of the grass website (updated once per hour).
- /osgeo/grass/rsync is the server which also operated as rsync mirror master (under the 'grass' rsync module)
Mediawiki (using mysql)
- GeoTools (http://www.geotools.org)
- /osgeo/geotools/geotools-web is GeoTools home using plain HTML
xblade15-2
- (198.202.74.220) FC4
- ldap.telascience.org: Fedora Directory Server. LDAP server.
- osgeo.telascience.org: Plone
- txtmob.telascience.org: SMS Smart Mob system
- gpstrack.telascience.org: Plone GPS / APRS / Cell tracking .... wishing ;)
- mediawiki.telascience.org (likely unused since wiki.osgeo.org ended up on osgeo2)
- ISO mirroring
sparcblade7
- (198.202.74.212)
- HJG still working to setup.
- HJG plans to use for a telascience ldap server.
- Frank Warmerdam / Mateusz Loskot plans to deploy buildbot slaves (bigendian sparc solaris!)
sparcblade8
- (198.202.74.213) Solaris 2.9
civicspace.telascience.org: experimental community portal- see SAC:Setup CiviCRM
hypersphere
- (hypersphere.calit2.net)
- Web based IRC client
