Mail server
From OSGeo
The production mail server is a Debian 10 LXD container administered by SAC, hosted on osgeo9.
See SAC#Communication in case of troubles or quick questions
WARNING: As of August 2026 the osgeo.org mail service is being migrated to hosted provider, see Soverin
Services hosted on the mail container
Postfix SMTP server
Handles outgoing and incoming email
Mailman
Websites
All websites are served by Apache
site path contact backup comments
www.tilecache.org /var/www/tilecache/docs SAC !? BackupOg6 bacula job
lists.osgeo.org admin Web interface for managing Mailman
MySQL server
TODO: review/cleanup
  • backed up via bacula in BackupOg6 job (see /osgeo/backup)
  • admin user credentials found in ~root/.my.cnf
SSL certificates
  • LetsEncrypt is configured using certbot-auto
    • careful: check the conf files in /etc/apache2/sites-enabled/ to make sure that the VirtualHost settings do not include something like <VirtualHost _default_:443> and instead should point to the IP such as <VirtualHost 140.211.15.14:443> or else the certificate loaded will always default to mapserver.org
    • certbot-auto lives in /usr/local/sbin.
    • to add more sites, run the command:
      certbot-auto --apache -d mapserver.org -d www.mapserver.org
    • a cronjob (certbot-auto renew) was created to check for renewal twice a day
    • also enabled for geos.osgeo.org on by Jeff McKenna on 2018-10-01
Backup strategy
See SAC:Backups for general info about backup strategies for containers.
A dump of each mysql database is also stored as a separate file under /osgeo (created during the backup phase).
