SAC Meeting 2019-09
From OSGeo
Where and When
  • in IRC on Freenode, channel: osgeo-sac
Meetings Happened
2019-09-12 Transcript
Status
  • STATUS osgeo4 #1940 - osgeo4 has been setup with LXD, wordpress-dev, old-wiki-dev, tracsvn-dev (still in progress setting up the test sites)
  • wordpress - www has been moved to osgeo7, imagemagick, bcmath installed, 2019-09-12 meeting was focused on issues with www site. jodygarnette observed QGIS was timing out giving 500. Libavatar-replace showing lots of errors in apache logs
Disabling libavatar-replace plugin seemed to fix the QGIS issue, also sped up viewing of Admin-users screen. Also ramped up memory to 8GB. Performance seems good now.
  • DONE Setup a nightly job on osgeo4 to copy over smaller key containers from osgeo7, (nginx, wordpress,secure and larger containers weekly (nextcloud,download)
  • DONE moved wiki from wiki.osgeo.osuosl.org to osgeo7 old-wiki container (its an image so everything on it is still old, we'll start working on a new one testing on osgeo4 first)
Agenda
Alex noted that the libavatar calls are each taking a second each so that could be one bottleneck. Some images are very big DONE: 2019-09-12 meeting was focused on issues with www site. jodygarnette observed QGIS was timing out giving 500. Libavatar-replace showing lots of errors in apache logs Disabling libavatar-replace plugin seemed to fix the QGIS issue, also sped up viewing of Admin-users screen. Also ramped up memory to 8GB. Performance seems good now.
  • Moving other servers - tracsvn, rest of old-www, wiki - express concerns. I'm planning to finish old-www next and then follow with wiki. tracsvn we need to do some testing on tracsvn-dev before I feel comfortable migrating
  • DONE: moved wiki completely to osgeo7 - imaged it as container old-wiki
  • TODO: Setup Bacula (need some thoughts on best way to go about this since osgeo7 is not setup quite the same and for some containers seems overkill to install a bacular fd client
  • TODO: Wiki is old and needs to be replaced the MySQL 5.5 EOL'd a couple of years ago for one.
  • TODO: 2339 Load balance download.osgeo.org using ftp.osuosl.org/osgeo/download - jef mentioned this Nginx load balancing redirect
Budget
  • OSUOSL donation and FunToo donation are we set?
    • FunToo submitted to monthly payment plan, did treasurer figure it out?
    • OSUOSL, need to submit request to treasurer. - Request was made June 27, need confirmation
System Contracts
  • DONE Regina -- Second contract in place
  • LDAP+SSH Keys
  • Migrating OSGeo Wiki Logins to OSGeo LDAP
Open tickets needing attention
  • Domain Renewals (needs ticket) Is GDAL all set?
Other topics
SAC main page
